Question about Fisher and Paykel GWL11 Top Load Washer
Start up Fault
My Fisher and Paykel (Model:MW511) flashes and beeps when I turn it on. It won't start a cycle and none of the functions can be programed. When I push the start button the beeping and flashing stops, but nothing else happens.
The spin light (red) and two of the lights to the left are the ones flashing.
Thanks
John
  • 1 more comment
  • nearwater Nov 10, 2008
    I can't find a trouble shooter in the console to determine what the blinking lights are telling me what the problem is. Could you tell me where I can find the sheet or a manual.
    Thanks
  • brown251 Feb 14, 2009
    I have the same dam problem. Does anyone know where to find a service/user manual for the Fisher and Paykel MW 511 Washing Machine.
  • Anonymous Mar 20, 2014
    Not spinning no codes
  • 72 Answers
As a guess its the elctronics board
Posted on Sep 25, 2010
  • roddy168 Apr 30, 2011
    Why does everyone assume it's the board? In 99% of these problems, its due to a loose sensor connection, a blocked pump or something equally simple. Go for the first options first and save yerself $350. Roddy
    President:
  • Fisher and P... Master
  • 2,651 Answers
There should be a trouble shooter in the console the blinking lights will tell you what the problem is and the common issues are listed on that paper.
Posted on Nov 09, 2008
  • Ron Coons
    Ron Coons Nov 10, 2008
    i dont know if they are listed onlline anywhere( actually om sure they are wouldnt know where to look though. i would call tha cust service center for f&p they have always been real helpful for me in the field...at the least they will be able to supply you with a manual
Why won't my Fisher & Paykel washing machine complete its cycle?
it appears to be a control module problem
have it checked by an authorised F&P technician
Jun 06, 2015 | Fisher and Paykel Washing Machines
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
Fisher and paykel start button does not actuate. The panel works, but just won't start the cycle
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Feb 01, 2013 | Fisher and Paykel (IWL12)
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
Fisher and pykel EcoSmart won't start
You can find a service manual at the link below to assist in repairing your machine.
Download the smart drive mw511 manual
Link:
Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel DD605SS
I can talk you through finding the fault on live chat. cheers
Mar 15, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
Mar 02, 2009 | Fisher Washing Machines
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
975 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
