Question about Jensen VM9410 Car DVD Player
Jensen vm9311 dvd indash volume is loud when i turn on car
I have the jensen vm9311dvd indash player... i just got it installed but when i turn on the car the volume is on max and about blast us out of the car...how can i fix this permenantly??? thanks thaman7
  • Anonymous Mar 14, 2014
    I hooked up a. Boos indash single din but when you put in a DVD plug in phone the volume isn't loud but the radio its loud when you turn it up
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Posted on Nov 30, 2006
Jensen car stereos have a "feature" called programmable volume memory. Maybe video players have the same thing. To set the startup volume, push and hold the power button. You might see a message about Memory or Volume. Then adjust the volume while holding still holding the power button. Definitely works for Jensen car mp3 players. HTH, Susan
Posted on Nov 25, 2006
    President:
  • 3,130 Answers
It sounds like you have something wrong with the volume control circuit inside the unit. The only way to fix this is to take the unit out of the car and have it bench tested or if you just got it or bought it, take it back for a new one. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 23, 2006
SOURCE:
BRAKE BY PASS FOR JENSEN VM9311
daughter formated my hard drive by mistake got no recovery disc but reinstalled xp but got no sound drivers
Sep 21, 2009 | Jensen VM9510 Car DVD Player
Turn on the car or the stereo, volume increases to really loud!!
Set the volume for how loud you would like it to turn on, then push in on the volume button for about 20 sec, that will fix it
Jul 30, 2009 | Jensen's VM9312 Car DVD Player
Jensen vm9311 motorized screen wont close
no it's not your battery it is in the screen itself , the motorization is broken or damaged . You will need to get that repaired by either taking it to a repair shop in your local area that services jensen products or send it back to the company. If you choose to send it back to the company you will need to contact them first to get a return authorization number .
Audiovox/jensen 1-800-645-4994
Jul 04, 2009 | Car Audio & Video
I just installed a VM9311 and when I turn the volume up it resets. Any suggestions?
check for loose wire in harness. Had same problem with 9412 that i have. Bought new harness at electronic express for 20 bucks. hope this helps
Jun 29, 2009 | Jensen VM9410 Car DVD Player
Jensen VM9311TS
try pressing the reset button.
Sep 07, 2008 | Jensen's VM9312 Car DVD Player
Loud switch
Call Jensen on this one. I have no idea as I don't one this unit.
Apr 28, 2008 | Jensen VM9510 Car DVD Player
How to activate the "LOUD" in my Jensen UV8
customer support suggested this: Turn the volume control, and while the yellow speaker icon is still visible, press and hold the volume control until you here a double beep. This confirms the new volume setting.
Dec 08, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311 AM/FM/CD/DVD
you are mising to power on the factory amp.
Apr 25, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen VM9410 Car DVD Player Logo
1,357 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
