Question about Linksys Wireless-G Range Expander (WRE54G)
Repeater cuts out
About a year ago we purchased a linksys repeater, in order to expand the range of our D-link router. While the repeater successfully boosts the range of our router, when connected to the internet via the repeater our internet cuts out every 60 minutes. After cutting out, the computer must reacquire the IP address, and the internet is usually working again within a minute. When connected to the internet near our D-link router however (such as just a few feet away from it) the internet connection never cuts out. This only happens when our computers are connected through the repeater. We have only taken minor steps in trying to solve this problem, such as reseting the router, etc. Any help on this issue would be greatly appreciated.
  • 779 Answers
I would suggest a few things 1) see if a firmware update for the device 2) It may be a DNS issue can you post the model what status are the lights on the repeater next do an IPCONFIG /ALL - see later and some ping tests to see if its a DNS ISSUE ipconfig /all TWO Methods to do that - some people have problems with ONE---- ONE --------------------------------- start run cmd ipconfig /all rightclick in the box select all enter control key + C key - to copy then reply here and control key + V to paste TWO ----------------------------------------------- Start, Run, CMD to open a DOS window and type: IPCONFIG /ALL >C:\RESULT.TXT Open C:\RESULT.TXT with Notepad and copy/paste the entire results here. NEXT lets see if you can get out onto the internet with both names and IP's - its possible the IP number you get back on the first test is different to the one I post {I'm in UK} so use the number you get instead of mine ------------------------------------------------ try ping the name and then the IP see below start run cmd C:\Documents and Settings\wayne>[b]ping {the default gateway ipaddress you got above }[/b] C:\Documents and Settings\wayne>[b]ping google.com[/b][quote] Pinging google.com [64.233.187.99] with 32 bytes of data: Reply from 64.233.187.99: bytes=32 time=120ms TTL=243 Reply from 64.233.187.99: bytes=32 time=107ms TTL=243 Reply from 64.233.187.99: bytes=32 time=102ms TTL=243 Reply from 64.233.187.99: bytes=32 time=101ms TTL=243 Ping statistics for 64.233.187.99: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 101ms, Maximum = 120ms, Average = 107ms C:\Documents and Settings\wayne>ping 64.233.187.991 Ping request could not find host 64.233.187.991. Please check the name and try a gain. [/quote] C:\Documents and Settings\wayne>[b]ping 64.233.187.99[/b][quote] Pinging 64.233.187.99 with 32 bytes of data: Reply from 64.233.187.99: bytes=32 time=116ms TTL=243 Reply from 64.233.187.99: bytes=32 time=113ms TTL=243 Reply from 64.233.187.99: bytes=32 time=113ms TTL=243 Reply from 64.233.187.99: bytes=32 time=111ms TTL=243 Ping statistics for 64.233.187.99: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 111ms, Maximum = 116ms, Average = 113ms C:\Documents and Settings\wayne>[/quote]
Posted on Apr 12, 2007
How do I CONFIGURE WI FI REPEATER
You'll need to configure your wifi adapter to the same network range as the repeater.
192.168.10.2 will work.
Jan 20, 2015 | Generic Wireless-N Wifi Repeater IEEE...
How can I use linksys wag200g as a repeater or to regenerate the signal, how can I connect wag200g with tplink router.
go to this link and it should give a good guide line best of luck
http://lifehacker.com/#!5563196/turn-your-old-router-into-a-range+boosting-wi+fi-repeater
May 05, 2011 | Linksys WAG200G Router
Link Light red activity light blue. Tried to reset and use the auto configuration button but nothing is working.
Hello, It sounds like the repeater is not within range of the wireless router or access point. The repeater does not act as a wireless router by itself, but rather like extra antenna/signal booster, so you still need to have a wireless router within range. The router must also be using a router that is 802.11B/G compatible, or else the repeater might not be able to receive that frequency signal in order to boost it (should work with N also, but not quite sure if it has to be set to Standard Channel due to how N works. We are working on wireless frequencies in my course now, so I can contact my instructor, and get back to on that). If you have any questions, feel free to contact me, or simply reply.
Feb 12, 2011 | Linksys Wireless-G Range Expander (WRE54G)
I got a wireless network connection home but the modem and router are both upstairs while my ps3 is downstairs. i bought wireless-g range expander model no. wre54g in order to expand my wireless network...
Hello
This not a big deal for a wireless network to work on downstairs, you need to check your connection and settings of the routers/computers. or just put a repeater for improvement of signal strength.
If the matter is signal strength, for the purpose see the TIP link below
http://www.fixya.com/support/r7245572-improve_signal_strength_wireless_network
Good Luck
Dec 13, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Malfunction of range expander
Good Day Sir, try to see the link below hope it will help you.
Linksys
thak you.
Apr 28, 2009 | Linksys Wireless-G WRE54G Repeater
Hiii
There are many different (possibly fun) ways to boost your routers signals. You can purchase better antennas (If you can disconnect your OEM ones, but those can be over priced). You can upgrade the firmware of your router (requires very good technical skill to properly and safely do that), then tweak those router settings then. You can make you own antennas. ( that requires some radio engineering skills to properly do). You can install an amplifier between the router and antennas (can be expensive). or any combination of the above, but be wary of FCC rules with any modification of RF equipment (don't make the signal too powerful, or cause interference to others in your area). :D
One more viable way is to use a repeater in another area of your home to repeat your routers signal where needed (repeaters are hard to find, can be expensive as well).
Jan 22, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless G range expander
Hi David,
I need to know that what type of router u r using.
If it is Linksys router just follow these steps,
with the help of the Ethernet cable connect the range expander to any one of the 4 ports in the router...
ur computer shuld be directly hook up to the router..
open internet explorer in ur computer..in the address bar type in 192.168.1.240(ip address of the range expander)
it will prompt for a username and password...leave the user name blank and the password will be admin.
u can see the linksys range expander set up page...
u can find SSID at the bottom of the page...
ur router's SSID and the range expander's SSID should be same..and also the password should be same..
If the ssid or password mismatch between the router and range expander u can find these kind of Error messages...
Good Luck....try it and revert back
Jul 03, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Range Expander (WRE54G) Logo
296 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
