Question about Frigidaire Kitchen Ranges
Frigidaire PFEF317AS2 ELECTRIC RANGE THE BAKE ELEMENT WON'T WORK, I'VE TRIED REPLACEING IT ONECE, WORKED A COUPLE OF TIMES NOW NOTHING, WORKS FINE IN BROIL.
5 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
  • 6 Answers
SOURCE: We have a ceramic top
check all wiring connections, if ok ohm out oven thermostat, if thermostat ok, ohm out oven elements and if ok, check voltage at oven elements. isolate problem.
Posted on Jan 25, 2011
wrightly
  • 140 Answers
SOURCE: Kenmore electric range 790.91011200 When set in
yes. you can do a simple continuity test to be sure (on the broil) element, but you're gonna spend at least 20 dollars on a volt/ohm meter. if you have one already, you're in luck. just remove the element and test the prongs for continuity (usually setting RX1). more than likely the element just needs to be replaced
Posted on Jul 07, 2011
SOURCE: Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Posted on Nov 24, 2011
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't bake
Sounds like a connection issue to the control panel and the lower portion of the unit. Contact a professional to have the unit diagnosed unless you find the ohm reading to be off for either broil or bake element.
Dec 26, 2012 | Frigidaire FEF352 Electric Kitchen Range
My bake or broil will not work but my stovetop works fine, as well as the clock and oven light.
Does the oven indicator light come on when you turn the oven on? Does the baking element or the broil element work by themselves but just don't work together? If nothing at all works did they stop working at the same time? Need to know to troubleshoot. Please reply with more info.
Feb 16, 2011 | Frigidaire FEF336BC Electric Kitchen Range
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jul 13, 2009 | Kenmore Kitchen Ranges
My frigidaire single oven(model # FEF365BWG) broiler works but the baking element does not work.
the element needs to be replaced as its not getting proper current because its got cut in between.many a times cleaning the element and refitting it again makes the device working.
Feb 20, 2009 | Frigidaire FEF365AS Electric Kitchen Range
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Fridgidaire stove oven baked potatoes one night the next day...nothing.
can you seee the lower bake element? usualy when bad it will be apparent with a visual inspection of the element.if there is damage to the element order a replacement . 2 screws and 2 wires . no problemTURN OFF POWER ITS A LIVE ELEMENT AT ALL TIMES!!!!!!!
Mar 16, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
85 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
