Question about RCA HD52W56 52" Rear Projection HDTV
RCA HD R56WH78 projection TV, picture just got ascew,
Looks like the 3 tubes somehow got unaligned mabey? 3-D type picture now, words appear 3 times 1 red 1 green 1 blue. My info bar is now rounded instead of being straight across the bottom of the screen like normal.
  • 1 more comment
  • PrimFolk Nov 30, 2008
    Where is the fuse located for the convergince ?
  • BuzzAlmighty Dec 02, 2008
    I do not have the convergence option in my menu. It was there before, I used to select every once in a while. Now its not there but I've never seen the 3 colors off by this much before.
  • Naturally Dec 08, 2008
    3-d effect
I followed willtab great directions and replaced my fuse less then 4 hours later it is now on 3d again.
Is there some other part that might be causing this if so what is it?
Posted on Nov 19, 2008
    Genius:
  • 1,030 Answers
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Posted on Nov 11, 2008
NEED PART NUMBER FOR PROJECTION HDTV. MODEL R56WH78 FOR THE PROJECTION BULB
Good Morning
your set does not have a bulb it has three CRT'S picture tubes . and if the set is not working its not likely that the crt's have all failed . you most likely have a circuit failure like a high voltage trippler block or some where else in the set . what are the symptoms at start up .
Oct 15, 2014 | RCA Televison & Video
My RCA 52" projection TV
Try these companys PTS 1-800-844-7871
Encompass Parts 1-800-638-3328
UED 1-800-648-6657
Go to website at Encompass and type in your model number fior list of Parts/Prices
Jun 23, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Picture looks a little warped.
This could do with the picture tube, or another internal error, or it could do with the source of the content playing, if you are connecting straight from a TV wall jack, then maybe the TV requires a HD component, try playing around with the TV setting and changing it from 16:9 to 4:3 aspect ratio see if that helps. There is a video on youtube I found of somebody taking apart the TV in order to fix it. xhttp://www.youtube.com/watch?v=RfyPxb-F6wM
Goodluck :)
Mar 14, 2011 | RCA D52W19 52" Rear Projection Television
I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rear proj TV picture keeps blinking out
comon sony problem Sony has and Ik circuit tha is suppose to not allow video in there is an uneven emission from the crts what you have on both sets the tube are getting so weak causing the circuit to kick in and out in other word you need crts inboth set and they are not avail new you can have them rebuild but the set will never look good again time to retire them
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony wide sceen projection tv kp-51ws510, my picture looks like 3 dimensional pictures , with a red highlighted all around the picture,how can fix this?
hi
this type of problem occurs because of 3 issues..
1.colour wheel
2.jungle 45e3 ic on D- board
3.cathode ray tube...
check them...
thank u..///please rate it
Jul 04, 2009 | Zenith R57W46 57" Rear Projection...
RCA R56WH78 3D Color Spectrum
Hello The common FL231 fuse problem that these set has can be identified by asking the question DO you have the convergence option under setup in the customer menu. If you do not then there is a 99 percent chance you have this. I have written detail repair instrucitons on this under my profile in the tips and tricks section of fixya. I use union electronics for parts but just google the part and you can find many distribitors of the fuse. should not cost no more than 5 dolars and if you can solder the repair shouldnt take more than an hour to complete. Be carefull and good luck. This repair is on you can do if you have any trouble let me know.
Nov 07, 2008 | RCA R56WH76 Projection Television
56" RCA HDTV Projection Model # R56WH78
This is a rear projection CRT TV (picture tubes)Not service-friendly (disassembly,getting parts)more problems compared to other brands....
Sep 12, 2007 | Televison & Video
RCA HD52W56 52" Rear Projection HDTV Logo
178 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
