Question about Toshiba gigabeat MES60VK Digital Media Player
Broken Display Screen
I have cracked my display screen and it has messed up the display.Is this replaceable?I have put in a new battery so I have been inside the gigabeat.Or is too complicated to find one and too complicated to put it in?Thanks !!!!!
    Problem Solver:
  • 16 Answers
Sometimes you can find them on eBay, but they are expensive. I bought a used S30 and put the guts of my S60 in it, to overcome the same problem.
It is also very, very difficult to change the screen. Trust me. Buy an old one, which has a good screen but some other fault.
You could, of course, just change the hard drive and use the rest of the new one...
Posted on Mar 03, 2009
I have a iphone 5 which is under warranty but the screen is broke the phone was still working fine until recently it now wont stay on will apple repair why it wont stay on under the warranty
Generally, a broken - as in one or several cracks in the glass front - won't cause the phone to fail to turn on, unless water or other liquids have gotten into the works.
You could take it in to the Apple repair place with the broken screen and ask them to check the battery first as that could be the problem. If they say the screen is the problem you could decide then what to do. Those screens aren't too expensive but the labor to remove the old one and install the new one amounts to a couple of hours. The phone has to be just about completely dismantled to replace the display. I replaced the display an an iPhone 4 and it tool me three hours work. The display/digitalizer only cost 16 dollars. The replaced display's glass was terribly cracked and crazed but it continued to work and it never affected battery life.
Mar 08, 2015 | Apple Cell Phones
The screen on my zeepad jellybean 7.0 cracked how do i know if i need a new lcd display. I already purchased the digitized touch screen replacement
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
92dabd2f-7f4a-4795-976d-d97d7e32fa0e.jpgthis is a broken Lcd (the screen is distorted by the lines or no picture at all)
83952950-d5b2-47e3-b228-81f41d0190af.jpgthis is just a broken digitiser (the screen below the broken glass works fine )
hope that was helpful
May 20, 2014 | Tablets & eReaders
One half display
you have an internal crack. You cannot fix this, the only option is to replace the screen or buy a new set. In most cases, it will cost more to replace the screen vs. buying a new set.
Nov 28, 2012 | Televison & Video
Broken Language Master Screen
Hello
cracked screens can not be repaired, the screen needs to be replaced to a new one.
check ebay.com for parts.
May be hard to find. You may have to buy a new one. or a broken one that has a working display.
Good luck.
Apr 16, 2010 | Franklin LM-6000 Speaking Language Master
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
Element 32" flat screen tv has cracked screen
Sorry, but it's not worth to buy just a screen (probably you cant find just a display), so better start searching replacement tv... Take a lookon amazon or something... Amazon com TV Have a nice day
May 27, 2009 | Element ELC-HS321 32 in. LCD TV
My mobile nokia 7610 has a broken display . can i replace it with a new display screen ?
I have nokia 7610 model, the display screen is broken.
How can I rectify that or what is the cost of display screen
Mar 01, 2009 | Nokia 7610
LCD television
The inside of the display panel is broken.
The cost of the replacement display would probably exceed the cost of a new set!
Jerry G.
Nov 08, 2008 | Vizio L32 32 in. LCD HDTV
Motorola razr v3 display went out
Either your flex cable is broken or came loose. Is the top left hinge button still intact? Is it loose at the hinge? You will need a Torx 4 screwdriver to take the LCD screen apart to check the flex cable inside.
May 30, 2008 | Motorola Mobility RAZR V3
Display screen
Looks like a LCD display problem. Send it back to where you purchased it to avail of the warranty replacement.
Mar 29, 2017 | LG F9200/F9100 Headset
Toshiba gigabeat MES60VK Digital Media Player Logo
47 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
