Question about HTC Control4 AVM-HTC1-B Home Theater Controller - Black System
Remote won't communicate with the Control 4 AVM-HTC1-B unit
My remote all of sudden stopped working. I tried to reset the Control 4 unit and only difference is that the link light does not come on, the power light is the only light on. I tried pressing the Red 4 ubtton on the remote, the LCD comes on but nothing else turns, already tried replaceing the batteries. Do I need a replacement or is there a fix for this.
Thanks.
  • ozeira Dec 16, 2008
    Same issue here...
2 Suggested Answers
  • 414 Answers
SOURCE: My Control 4 AVM-HTC1-B no longer tunes the
Power outage is very likely to kill these systems, your best bet (I'm assuming these are in your area) - would be crestron, they supply at around the same prices and their products are highly reccomended.
Try http://www.crestron.com/ or failing that you're going to pay through the nose for similar equiment from other higher end dealers.
Wish you the best of luck and happy new year! And invest in a surge protector for 2011 :)
Posted on Jan 08, 2011
How do I select video mode on TV without remote control
Try getting a universal remote, not all functions are accessible through console
Apr 26, 2014 | Sanyo AVM-3259S TV
Replacement remote control sanyo model AVM-2507
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more details about this, try the sites linked here. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Sanyo AVM-2507 25" TV
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 09, 2012 | Televison & Video
I'm trying to obtain the remote control code for a SANYO (model#AVM-1906). I'm trying to program it into a universal GE tv remote.
Hello
Univeral remote code for TVs with GE universal remote are:
0047, 0051, 0055, 0021, 0178, 0027, 0135, 0282, 0451
Three digit remote codes for Sanyo TV with GE universal remote control are:
049/097/110/004/265/012/108/180
OK.
Jul 08, 2011 | Sanyo AVM-1906 TV
All of the sudden the remote control does nothing, won't work at all. What can I do?
try to remove the batteries from remote, if that don't work, unplug main unit from wall for 40 Min., and it will reset back to normal.
Jun 09, 2011 | Bose Audio Players & Recorders
Control4 remote reset sequence
The SR150 and SR250 remotes can be re-imaged. The V2/1 remotes cannot, any problems they have are always battery related. Remove old batteries and wait at least 2 minutes then replace with new batteries. This will reset the remote but you may need a technician to reset the Zigbee network.
Jul 10, 2009 | HTC Control4 AVM-HTC1-B Home Theater...
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
HTC Control4 AVM-HTC1-B Home Theater Controller - Black System Logo
671 people viewed this question
Top HTC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a HTC Audio Player and Recorder Expert? Answer questions, earn points and help others
