FAT32 to NTFS results in HDD failure
Changing my IBM laptop XP installation from FAT 32 to NTFS with 3 partitions, when at 35% the process stopped, I waited for 30 minutes more, but nothing happened aftter that. I restarted the laptop, but now it says that the hdd does nor exist. HELP please
  • pendragon2 Nov 09, 2008
    Is there a way to UN-corrupt the partition?
    Data recovery is not important, as only XP professional was loaded on fat32.
    What I initially wanted to do was , set up 3 partitions, all running NTFS than re-install XP.
    Maybe i did not make it initially clear enough: I can not access the hdd, on booting it keeps coming up with " the hdd does nor exist" This being the case, I can not format a hdd, as I can not access it.
    That is why I posed the question here in this forem.
    What I need is a program that runs as a self booting CD to format he HDD.t
    I spent over 3 days looking around on the net, as it now has become a challenge, for a fix.
    I tried numerous programs, but all seem to require to run on the HDD, non seem to want to run on a cd.
    The IBM laptop does not have a floppy disc
    I tried the Ultimate Boot cd (UBCD.com, i think) it does not recognise the hdd either.
    Surely, there must be a program somewhere that can access, or at least force access to this so-called non existing hdd.
  • 24 Answers
Your partition is now corrupt which may or may not be related to your hard drive being physically bad (though most like is a bad drive). You can MAYBE retrieve data from it if you take it to a data recovery specialist or get the proper hardware to hook the drive up to a working desktop/laptop and obtain data recovery software like Ontrack Data Recovery.
Posted on Nov 08, 2008
  • Brad Hamilton Nov 09, 2008
    Well you're going to have to reinstall windows from scratch or via a recovery CD. It is possible you drive is good and during a re installation if you do a full format (not the quick one) you'll find out if it is at least functional enough to install windows on it. It honestly sounds like a bad drive so you may wanna expect to need a replacement drive and do a fresh load on that.
  • Brad Hamilton Nov 12, 2008
    "HDD does not exist" error means your hard drive is dead. The good news is that it shouldn't be the motherboard as IDE controllers don't fail but once in a blue moon.
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
What is the difference between ntfs & fat
This are the difference between the two.
File Allocation Table (FAT): A file system used by MS-DOS and other Windows-based operating systems to organize and manage files. The file allocation table (FAT) is a data structure that Windows creates when you format a volume by using the FAT or FAT32 file systems. Windows stores information about each file in the FAT so that it can retrieve the file later.
NTFS: An advanced file system that provides performance, security, reliability, and advanced features that are not found in any version of FAT. For example, NTFS guarantees volume consistency by using standard transaction logging and recovery techniques. If a system fails, NTFS uses its log file and checkpoint information to restore the consistency of the file system. In Windows 2000 and Windows XP, NTFS also provides advanced features such as file and folder permissions, encryption, disk quotas, and compression.
Dec 05, 2010 | Computers & Internet
Hi i got gx270 and i made a bootable acronis disk director on a flash so i can format ntfs to fat 32 as i tried before to install win xp from a flash drive but got a stop message sayin i should check...
First of all I have to ask why you are trying to load FAT32 instead of NTFS. NTFS is the preferred file system for all Operating Systems after Windows 2000. Also, you cannot format the hard drive through the Windows XP installation for larger than a 32 GB partition. If you need a larger partition, I suggest using a floppy drive with the3 WinME bootdisk loaded on it. You can get it here:
Try the WinMe bootdisk from http://www.bootdisk.com/bootdisk.htm
If the above is not the issue than we can move forward with other solutions.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell OptiPlex GX270 PC Desktop
Trying to install windows xp media edition on a new 250gb pata HDD on a dv8305us hp pavilion laptop. I get to the partition phase and the computer shuts down
did you format the drive? and what in? ntfs? quick? full? FAT 32 ? cause you need to go back and run a FAT 32 format to every get xp to load on that machine
Jan 14, 2010 | Office Equipment & Supplies
T30 cant find os
when you start does it come to point where it shows xp and ibm
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
Expand Partition of Hard Drive
My advice is start fresh with a new hard drive, install XP on it, then use partitioning software while running XP to create an NTFS partition on the remaining space of your old hard drive if you must keep your FAT32 partition.
An alternate method would be go to the manufacturer of your hard drive and download their partitioning software. Often it will run from a floppy or boot cd and you can partition as you like using it. Keep in mind, repartitioning a drive, especially an older one, has a bad habit of making the old existing data unreadable if you're not experienced so make sure you have a back up.
Jan 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Can not convert it to fat or fat32 file system
Using disk manager, try to delete the partition. Then start over again.
Hope that helps...
Geno
Feb 27, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
