Question about Hoover 24 in. HD98E Built-in Dishwasher
Arms not rotating
Hoover HD 98 E dishwasher just stopped working. Soap tablet undissolved, Heater element working and filters are all clean, Could it be the pump and can we fix it ourselves?
    Problem Solver:
  • 12 Answers
Pull out washer disconnect lines unplug it open the door pull out the racks(room to work) look for any stray parts laying at the bottom(small black belt,srews any metal debris)if you find any of that try to find where it came off of.it sounds like a pump problem easy fix connect hoses to pump and mount the pump.check all hoses and spray tips thoroughly
Posted on Nov 09, 2008
Tip
What to do if your Dishwasher isn't cleaning well...
Check the following when experiencing poor cleaning results:
- Dispenser (Where you put the Dishwasher Tablet or Powder)
Make sure that the flap holding the powder in is not loose.
Make sure it is dry before ever putting in powder.
- Dispenser (Flap Type)
To check if it is still opening for the Spray Arms (Spray Arms need to throw water on the Powdered contents to wash the dishes) - Put the Dishwasher in a cycle, and halfway through the cycle, open the door. if it has not opened then maybe the solenoid/actuator needs to be replaced.
- Program Selector (Not the component, the function selected)
More time consuming programs are more likely to wash more effectively, try selecting these with a higher heat setting instead of your usual programs like quick wash etc..
- Machine overloaded.
Make sure the baskets are not overloaded with dishes, mugs & glasses as this can make spray arms find it more difficult to clean between them
- Soap
In tests regarding powder vs. 3 in 1 tablets like "finish", it has been shown that powder gets dissolved much better, this is because the 3 in 1 tablets are designed to disintegrate on certain heating phases of only a select few brands of Dishwashers. So if you are unsure, or experiencing undissolved tablet - Use powdered dishwasher soap instead.
- Salt container
Refill the Salt container every 3 - 4 months depending on how frequent you use the dishwasher
- Spray arms
These can often be clogged with dirty water etc. clean these with toothpicks and pressured water.
- Filter
Clean these every time after a wash, usually found at the bottom of the dishwasher where water drains away.
- Over the counter products
These can be bought at Appliance spare outlets or even at some supermarkets. Use these as the directions indicate.
- Element (Last step if not improved)
Replacing a element is usually a last option, if no improvement was experienced by doing all of the above it could be that the element is not heating at the right temperature, or not heating at all.
Either replace this yourself (with various degrees of difficulty depending to the Make and model) or get a qualified service technician to do it with you.
Hope this helps :-)
If you found this helpful, please vote accordingly.
on May 10, 2011 | Dishwashers
UPPER ROTATING WANDS DON'T ROTATE. lOWER WANDS DUE. I HEAR A DRIBBLING SOUND. EVERYTHING ELSE APPEARS NORMAL BUT SOAP DISPENSER DOES NOT DISPENSE SOAP-THANKS.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 27, 2011 | Dishwashers
The soap does not dispense entirely (the soap dispenser opens okay) The dishes have a soap film and at times food residue on them... It appears that not enough water is spraying on the dishes. Is there a...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 12, 2011 | Kenmore 24 in. 17019 Built-in Dishwasher
I have a Kenmore built in dishwasher. Serial Number 15989990 Model 665. My dishes are not getting clean. Lots of residue on glasses on top rack and dishes streaked. Any ideas? We thought it might be the...
Dishwasher
How to Buy
heatman101
Asker
Mar 06, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a kenmore elit i can put soap in the holder and close it but when cycle is done there is some soap left and the dishes are not that clean any soultions
Dishwasher
How to Buy
heatman101
Dec 20, 2010 | Kenmore Elite Stainless Steel 24" BuiltIn...
Clear glasses and silverware have film and some particulates. Silverware is on bottom and glasses on top. It's a KUDS03FTSS3. Have had the filter area cleaned. Have used vinegar. Have used less soap,...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker
Nov 12, 2010 | KitchenAid Dishwashers
My dishwasher is not cleaning my dishes and is leaving half of the soap, i have cleaned the arms, check for the heater element, check the water temperature at that all seems in order, i have used different...
heatman101
kl769
Sep 06, 2010 | LG 24 in. LD-12BW5 Free-standing...
Soap cup
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
p
Jul 29, 2008 | Kenmore 24 in. 16269 Built-in Dishwasher
UNDISSOLVED SOAP RESIDUE AND
Dispenser door sticking. Run it a few cycles by putting the tablet in the cutlery basket.
Mar 22, 2008 | GE 24 in. GHDA986KSS Built-in Dishwasher
Hoover 24 in. HD98E Built-in Dishwasher Logo
299 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
