I am trying to re inestole my X3550 printer but in each time insert the DVD it appearrs as if it is empty DVD
    Master:
  • 568 Answers
There may be problem with your dvd or dvd rom
Posted on Nov 08, 2008
My x3550 printer alignment is off. when i print or make copies it comes out of alignment. my printer is not that old, i hardly use it much. i would like to figure out how to fix this.
It could be the cartridges in the printer. Remove the cartridges from your printer. While the printer cover is open, check the cartridge carrier path and make sure there are no foreign objects obstructing its path. Close the cover. Unplug and replug your printer into the power source to reset it. When your printer turns on, reinsert the cartridges. Let it print an alignment page. If problem continues, try to insert a different known good cartridge.
Apr 16, 2011 | Lexmark X3550 All-In-One Printer
My Lexmark x3550 only prints one page of multiple pages. I've checked my print setting and it all looks correct. I'm also having problems scanning and copying. It's a fairly new machine as I hardly use...
Try to reset your printer factory default settings. Press Settings button -> Defaults -> Set Defaults -> Use Factory -> press Check. You will be asked to setup your printer settings like you're setting it up the first time - set the time and date, etc. When done, unplug and replug the printer into the power outlet to refresh the printer.
Apr 13, 2011 | Lexmark X3550 All-In-One Printer
I need to reset my ink levels so my X3550 refilled cartridges
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Oct 22, 2009 | Lexmark X3550 All-In-One Printer
I have installed a black 23 print cartridge in my x3550 printer, and it is indicating that the cartridge is incorrect, however, this is the same cartridge that is required.
Left/Right Cartidge Incorrect - huh? The printer is saying Left Cartridge Incorrect or Right Cartridge Incorrect,
and you are sure that you inserted the correct cartridge, a #23 or #24.
A small number of #23/#24 cartridges will report as Incorrect Cartridge because
of a manufacturing issue. There is a firmware upgrade available to fix this problem, and allow
the printer to accept the cartridge.
3500-4500 Series (X3550, X4550)
3400 Series (X3430)
1400 Series (Z1420)
To apply the upgrade:
  1. Make sure the printer is turned ON and connected with a USB cable.
  2. Download and run the appropriate update program using the links above.
  3. Be careful not to disconnect or turn off your printer while it is being updated.
When the update is complete the printer should automatically restart and accept the #23/#24 cartridges.
Jun 18, 2009 | Lexmark X3550 All-In-One Printer
My printer cartridges Lexmark X3550 numbers 23 and 24 only print about 20 pages and then my cartridges are empty to pay R379 and R349 is a lot of money to waste so often is there something wrong with...
yes its definitely faulty or then the cartridges are, get it serviced or complain about the cartridges, the other one is faulty.
my hp printer and its cartridges print out 100's of pages... I don't have a lexmark but I know its not supposed to print only 20..
Jun 12, 2009 | Lexmark X3550 All-In-One Printer
Refilled lexmark 23 cartridge but still shows
clean the terminals with damped cloth not wet
 try using a pencil eraser
Jun 11, 2009 | Lexmark X3550 All-In-One Printer
My Lexmark x3550 isn't using the photo cartridge.
There is no way to use the photo cartridge by itself, it is intended to supplement the color cartridge, so printing with just the photo will not give you good results, even if it were possible.
Apr 14, 2009 | Lexmark X3550 Printer
X3550
What has happened to it? Did it have apaper jam? Let's try a simple reset first.
Turn off the printer and unplug it.
Open the paper jam door and gently roll the paper roller forward until it clicks. close the door.
Leave the printer unplugged for a few minutes then plug it in and turn it on and try it out.
If this does not solve your problem, you may need to reinstall your software. If you do not have it, let me know.
Aug 15, 2008 | Lexmark X3550 All-In-One Printer
Refilling cartridge
cucujo, you were not as lucky as lovetofish! Sooner or later the printer will win.
The money for printer manufactures is not in the printer, it's in the ink refills. With this in mind many printer Mfg's have added small chips to their ink cartridges. These chips track the amount of times the printer prints. The software knows you are adding ink to the cartridges. Many people find they can get around this by keeping their old cartridges & refilling. Some HP users keep as many old cartridges as three. Rotating ink cartridges. This seems to work for most printers. Suggest you try the same. Continue to fill you're ink cartridge but replace with a new cartridge. When it empties replace with another new. The next three will be re-filled ink cartridges. Always refill as soon as possible, never turn ink cartridges on their sides. Keep refilled cartridges in an airless zip-lock bag, in a cool & dark place when storing.
Mike
May 05, 2008 | Lexmark X3550 All-In-One Printer
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
