Question about Samsung SPH-M500 Cellular Phone
SPH-m530 Ringtone How to
I have transferred my MP3s to the memory card in my phone. I am trying to set the ringer with one of the songs but cannot figure out how this is done. I do not have Internet time with my phone so I cannot send and then download. Should I be accessing them another way? There is an option to use "my videos" as a ring tone but not my music! Seems unusual!
  • shaunhamel Nov 24, 2008
    Same thing, I can put files on my memory card, but there's no way to set them as my ringtone.
  • Anonymous Jan 14, 2009
    as above
You need to have the internet for a short time to send yourself ringstones to work, maybe you can try looking them up from your card and assigning them to contacts.
Posted on Nov 25, 2008
  • Anita Whitten Nov 25, 2008
    ps you cannot set mp3 for ringtones they have to be a ringtone format you should try a conversion program to make ringtones from the mp3 for them to work on this phone I believe
Can I use music off my memory card as a ringer?
For some phones yes, however sometimes certain phones will need the song to be moved from the memory card to the phones internal memory.
Jul 28, 2009 | LG RUMOR Cellular Phone
Need to know hot to get a ringtone off a memory card to a lg rumor phone.
i dont know exactly about the rumor, but this is usually a two step process, depending on the phone. If you already have music on the SD card, you need to go to your music files and select the one you want as a ringtone, then pull the menu up (the equivalent of right-clicking on a computer) by probably pressing the menu button when on the selected song. There should be a command that basically is " set this as a ringtone", which you should then select and accept.
Now depending on your phone, you might not even have to do this first step. You can go to either the phone menu, where you should access where you go to configure ringtones, idk if its sounds, phone, theme, whichever one. Here, the song you chose should appear along with the default ringtones that came with the phone. Hope this helps, hit me up if you still can't get it.
May 25, 2009 | LG RUMOR Cellular Phone
Mp3 down loads wont download
I believe you have to send the song to your phone and store it on a external memory card.The E815 phone doesn't allow you to use songs as ring tones as far as I know.
Mar 29, 2009 | Motorola Mobility E815
Cannot apply mp3 ringtones as ringers
U really need the phone tools disk to change your songs into useable clips. This phone won't play a full song as a ringtone, only clips. THe software is really easy to use and you can find it on ebay fairly cheap, just make sure to enter the correct phone into the software for correct support. Good luck!
Oct 22, 2008 | Motorola Mobility ROKR E6 Smartphone
Lg scoop phone AX260 need help transfering mp3 from computer to ringtones
There actually IS a way to use your own MP3s as ringtones. You will need Web Access from Alltel, which costs $1.99 per day or $5.99 for a month. I put up a step-by-step guide to successfully using MP3s as ringtones on my blog: http://blog.edirectories.info/2008/09/add-mp3-ringtones-scoop-ax260/
May 08, 2008 | Lands Phones
Bluetooth
to assign a downloaded MP3 Ringtone as the handset Ringtone follow the steps below:
  1. From the MP3 side, while in standby mode, press the Menu soft touch key
  2. Select My Contents
  3. Select Ringers
  4. Highlight the MP3 Ringtone, using the navigation keys
  5. Press the right soft touch key for Options
  6. Select Set As..(2)
  7. Select Voice Calls (1)
  8. Highlight either With Caller ID (1) or No Caller ID (2), using the navigation keys
  9. Press the m620%20center%20navigation%20key-mp3%20side%5b1%5d.jpg key to confirm setting the MP3 ringtone as the handset's Ringtone
May 04, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Sph-m500 transfering songs onto phone
i have 3 programs that you need to do this from your pc to your mobile...
google and download these programs
goldwave (this is your ringtone maker)
p2kcommander (this is the transfer program)
and depending on the brand of phone you have....i have motorola so i use this program
motorola software updater (this is the connection from your phone to your pc)
May 02, 2008 | Samsung SPH-M500 Cellular Phone
Download songs from my PC to my upstage, how can I set them as a Ringtone??
1.as for ur ring tones u need them to be saved to the fone aswell they wont work as a ringtone unless the tune is saved to the fone
Jan 14, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Ringer ID won't work
If this doesnt work then your phone must be possesed..
1. Go to your phone book.  Choose a contact.
2. Go to options. Then Edit Contact.
3. Now scroll down all the way to Ringer ID:__ and hit select it.
4. You should see a list of songs  and sounds like silent, Vibe Dot.. etc
5. Scroll down until you want the ringer for that contact.
6. Once you found the ringtone hit select it.  You should now have the ringtone for that contact.  NOW hit "DONE" or it will not work!  If you dont hit done it will use the DEFAULT ringtone provided by the phone.  Also, if you have a memory card in your KRZR k1 and all your songs are on the memory card you wont be able to use it, move them to your phone memory so you can choose it from the list.  mobiles24.com also can give you free ringtones too.. check it out.
Jun 23, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung SPH-M500 Cellular Phone Logo
878 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
