Question about Polk Audio PSW250 Subwoofer
Polk Audio PSW202
I install a new fuse and plug in my subwoofer and it continually blows fuses.
  • 308 Answers
The power supply or amplifier has a shorted component.
Posted on Mar 12, 2010
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
Rw12fuse blown klipsch subwoofer. The new fuse blows instantly. What else can I try?
If it's continually blowing fuses you have an internal circuit problem, best to take it in for repair at that point.
Sep 22, 2012 | Klipsch RW12 Subwoofer Speaker
I recently purchased model vrvd640g and it continually blow fuses. my installer says the power supply is defective. can you help or replace the unit?
the problem can be solved my unit blew the fuses on the harness and actually melted the plastic that held the in line fuses in so i went to pep-boys and bought 3 hevy duity in-line fuses and cut and spliced them into the harness removing the 3 original factory in-line fuses and i never had that problem again and also for the cars radio fuse i replaced it with a higher amp fuse so i took out the 1amp red fuse and replaced it with a white 25 amp fuse or u can use a green 30 amp fusethey are all the same size they just dont blow with the new power load of the radio.
Sep 15, 2010 | Car Audio & Video
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Fuse blows
Both 3 or 4 amp slow blow fuses are suitable replacements for the 3.125 amp subwoofer fuse.
It could be that the subwoofer is blowing the fuse because the one you installed was not slow blow.
But, more likely is the subwoofer has a short in the power supply which is causing the fuse to blow.
May 31, 2009 | JBL PB10 Subwoofer
Polk Audio PSW202
first you have to check any short circut , that may be inside of sub woofer unit .
find and sove any short circutry and then only replace the fuse with same rating.
and before you switch on it once again recheck any meterial shored with electronics pcb.
Nov 08, 2008 | Electronics - Others
Polk Audio PSW250 Subwoofer Logo
545 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
