Question about Uniden BC60XLT Handheld Scanner
Uniden bearcat 50 channel mhz
Just got the scanner from a friend for 25.00 but no plug in cord and no manual
i am from michigan holland mi would like to more about this unit and how it works so far it is picking up good
Check oline under Uniden for a link to the instruction manuel, there are stores which yoou can learn of at same location by zip code to buy an antenna JD
Posted on Dec 14, 2008
Need antenna
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Dec 03, 2012 | Uniden Bearcat 855 Xlt 50 Channel Scanning...
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
Why can't i listen to aircraft pilots & tower on my Uniden bearcat BC60XLT-1? Our airband frequency here is 108-137 mhz.
Your scanner does not receive frequencies between 54 and 137 MHz, and there's nothing you can do to enable reception in that block. Your only option is to purchase a scanner with air band coverage. Here are the reception ranges of the BC-60XLT-1:
29.0-29.7 MHz 10 Meter Amateur Band
29.7-50 MHz VHF Low Band
50-54 MHz 6 Meter Amateur Band
137-144 MHz Military Land Mobile
144-148 MHz 2 Meter Amateur Band
148-174 MHz VHF High Band
Above bands in 5 kHz steps
406-420 MHz Federal Government
420-450 MHz 70 cm Amateur Band
450-470 MHz UHF Standard Band
470-512 MHz UHF "T" Band
Above bands in 12.5 kHz steps
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Bill B.
Listening in since the 60's
Feb 26, 2011 | Uniden Radio Communications
Uniden Bearcat bc560xlt scanner What radio bands (frequencies) will this radio monitor?
The BC560XLT is a basic 16-channel scanner that covers 29-54, 136-174, and 406-512 MHz. For information on the users of these bands, and complete information on using this scanner, you can download and print the operating manual here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC560XLT%20%28Manual%29.pdf
For a comprehensive database of the frequencies and systems in use in your area, visit:
www.RadioReference.com
Bill B
Sep 17, 2010 | Uniden Radio Communications
How to program the frequencies on a uniden bearcat 50 channel 800 mhz radio scanner?
To program the majority of non-trunking Bearcat scanners,\:
- Power the scanner ON
- Press MANUAL to stop scanning
- Enter the channel # to program followed by MANUAL (OR just press MANUAL repeatedly to advance to the desired channel).
- Enter the desired frequency, including the decimal point.
- Press E (ENTER)
If these steps don't work with your scanner, please provide your model number and I'll get back to you with specifics.
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
I have a older uniden bearcat BC860XLT and dont no how to program
Programming steps and many other questions can be answered in the scanner's operating manual, which can be downloaded/printed here:
http://www.uniden.com/pdf/BC860XLTom.pdf
Bill B
Feb 16, 2010 | Car Audio & Video
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
How do i program a uniden bearcat sc150 scanner
my parents gave my son a uniden bearcat twin turbo sportcat SC 150 Y. How do you program it
Jan 11, 2010 | Uniden Office Equipment & Supplies
Need a free printable user manual for Bearcat scnner BC142XL
Its so easy to use you really don't need a manual for the Uniden BC142XL scanner.
Push number 1, then push "MANUAL" again. This should leave you on channel one.
Using the keypad enter the frequency you want to monitor, then push "E." Press "REVIEW" at anytime to see what frequency is programmed there. If the review button flashes 000.0000 on the LED readout display, you might be entering an invalid frequency. Refer to the list of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push "E." Push "MANUAL" to step to channel three. Repeat this process until all the (10) channels are full, or you've run out of frequencies to enter.
radio will stop when it hears someone talking, and resume scanning two seconds after the conversation has stopped.
If this helps, please take a moment to give us a rating -- and a rating of "very helpful" would be greatly appreciated.
Sep 06, 2009 | Uniden BC-95 XLT Scanner
Uniden BC60XLT Handheld Scanner Logo
263 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
