Question about Blanco Plumbing
Blanco Faucet Side Sprayer
Help: black plastic shank that holds the side sprayer base to the countertop keeps sheering/breaking off at the base just above the countertop surface. I do not believe that I am over tightening the nut under the countertop. My Blanco sales guy says he has never heard of this.....thoughts, pls?
  • 374 Answers
It may be a result of extreme temperature changes from the time you tightened the shank until the time it broke however this is very unlikely.Typically the shank only needs to be tightened until it is stationary and immovable by normal operating stresses which is a very low torque value. As a general rule of thumb I use finger tight and an additional quarter turn. I once used epoxy and a short nipple to resolve the same issue but I had the advantage of having a pipe threading machine to fabricate the perfect size nipple and used a large washer and coupling to finish it off. If you try a new shank try tightening it as little as possible and I believe this will resolve the issue. Thanks for using Fix Ya and I hope this is of assistance to you.
Posted on Nov 09, 2008
How to disconnect sprayer hose on kitchen faucet?
Turn off the water supply valves beneath the kitchen sink. Turn on the faucet and squeeze the trigger on the sprayer to empty any water left in the supply lines, faucet and sprayer.
Trace the sprayer hose from the end of the sprayer to where it connects to the faucet. Use pliers to loosen the connector holding the sprayer hose to the faucet.
Remove the sprayer hose from the faucet to expose the male threads. Wipe the threads dry with a towel. Wrap the threads with pipe-joint tape. Twist a 3/8-inch threaded brass flair cap onto the male threads. Use the pliers to tighten the cap.
Reach beneath the sink and loosen the mounting nut securing the sprayer support to the sink or countertop. Use a basin wrench if you are unable to reach the mounting nut with your hand.
Slide the mounting nut off the hose attached to the sprayer beneath the sink. Pull the sprayer support and the sprayer from the hole in the sink or countertop.
Insert a sink hole cover into the hole left by the sprayer. Depending on the style of hole cover, it could snap in, or a mounting nut could hold it in place.
Things You Will Need
  • Pliers
  • Towel
  • Pipe-joint tape
  • 3/8-inch threaded brass flair cap
  • Basin wrench
  • Sink hole cover
Dec 01, 2017 | Plumbing
Faucet insert replacement
Contact Blanco to find out why the insert they sent doesn't fit.
Oct 28, 2017 | Blanco 157-090-CR Rados Kitchen Faucet...
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
I just installed a blanco faucet with sprayer. Turned water back and then tried faucet but no water comes out. Help
Turn water back off loosen supply lines from faucet turn water back on slowly with supply lines draining into bucket so as to flush them out.If water flowed ok reattach lines to faucet turn both angle stops on full and turn faucet on pivoting handle in all directions.If it still doesn't work take the sprayer line loose from the spout try turning the faucet on again with the line in a bucket. By now you have narrowed it down and the problem should be obvious.Also make sure a shipping plug was not left in line. Hope this helps
Jun 24, 2010 | Blanco Classic Single Handle Faucet with...
Delta single handle pull-out sprayer loose from base. How to tighten it?
Pull out sprayer has a plastic nut to tighten under countertop. You should be able to reach underneath and hold the top while tighting the bottom.
It designed to be tighten by hand to avoid damaging.
May 19, 2010 | Delta Faucet 470-DST Signature Diamond...
How do I replace the side spray base for my Blanco 086-ST Sprayer?
Hello. The side spray base is held in place with a washer and a nut on the underside of the sink. Sometimes this nut gets a bit corroded and can be difficult to remove. Here is what you will need to do. Borrow or purchase a faucet wrench. These are available at all hardware stores, home depot, lowes. Also get a can of a lubricating spray called WD 40. This is sometimes a two person job so call a friend. One person under the sink and one above, use the faucet wrench to grab ahold of the nut surrounding the hose. As you are looking up at it it will come off by turning it counter clockwise. If it doesn't come right off spray it with WD-40 and leave it for 30 minutes while the penetrating oil does it's magic.
You will also have to unscrew the sprayer and pull off the little metal keeper that will keep the hose from sliding through the opening.
Once these things are done you will have removed the old base and you will be ready to replace it by reversing the steps. Regards, Joe
PS kindly rate my answer. thank you.
Jan 26, 2010 | Blanco Essence Kitchen Faucet with Side...
Low water pressure/slow flow Blanco Elan faucet 2.2 gpm
pull the sprayer out, get some plyers or a wrench and losen up the connection. between the hose and the sprayer there is usually a screen take it out and walla it should take care of you, it also helps to leave the sprayer in some lime away or vinegar for a few hrs to get the hard water losened up in it
Jun 27, 2009 | Blanco ELAN II 1 Handle Pull-out Spray...
Blanco side sprayer fell off the hose
If the sprayer fell off the hose and you see no threads to screw it back on with, then the retainer clip has gone bad. Unscrew the sprayer at the bottom of the piece that came off the hose. There should be a little metal clip. That clip holds the sprayer on the hose. If the clip came off once it will again. Buy a new sprayer assembly with a new clip, unless someone has one sitting around.
Please rate this response and good luck, Phil
Dec 28, 2008 | Blanco Essence Kitchen Faucet with Side...
Plumbing Logo
162 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
