Question about Samsung HCL4715W 47" Rear Projection Television
I have a Samsung 55" model hcm5525w that has a horizontal dark line that moves up and down on the screen. The lighter or brighter the back ground, the worse the line.
  • 3 Answers
More than likley it is your proscan board.
Posted on Dec 10, 2008
MY SAMSUNG TV MODEL HCM5525W 55 IN IS STUCK IN TIMER MODE AFTER IT WAS UNPLUGGED. DO YOU HAVE ANY SUGGESTIONS TO FIX THIS PROBLEM?
You need to reset the tv to factory mode by pressing a code with the tv off,,,, mute--182--power and wait to see the menu appears on screen chose *reset to factory* press ok and wait until process done, them turn it on .
Dec 18, 2010 | Samsung HCM5525W 55" Rear Projection...
I have a Samsung HCM5525W that distorts horizontally across the top and bottom after it has been on about 15min. Center of picture is fine.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
Dec 25, 2009 | Samsung HCM5525W 55" Rear Projection...
its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
and for convergence settings
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
thanks.
Oct 05, 2008 | Samsung HCM5525W 55" Rear Projection...
Service Manual
You can get the service manual for your model at the following link. They email them to you, usually within minutes of ordering.
http://servicemanuals.vstore.ca/
Apr 03, 2008 | Samsung HCM5525W 55" Rear Projection...
Screen Issues
Grounding problem. Sometimes too much, sometimes too little, grounding is a hard one to wrestle to the ground. Due to the possibility of ground loops, too much grounding can be as bad as too little.
Try unhooking all your components and see which one causes this thing to happen when it's HU'd.
The most common offender is having cable hooked up, whose grounding can cause this phenom and also grounding hum in the audio. You can get an isolating filter for cable grounding that allows the cable signal to get thru without allowing the grounds to connect to each other. This usually solves the problem.
Mr Bob
Feb 02, 2008 | Samsung HCM5525W 55" Rear Projection...
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
