Question about Onkyo TX-SR505 Receiver
Onkyo TX-SR705 speaker hum
I'm having the same exact problem you posted. If you go into the "Speaker Settings" menu on the receiver's setup (menu 2-1) does the hum stop? You don't even have to change anything, just go to that menu. It stops when I'm on the menu, but as soon as I exit the menu it comes back. I've tried disconnecting everything but the speaker wires and I can still hear the hum. I've owned the receiver since March 08 and this just started happening a week ago. I have removed all inputs to the receiver, including speaker wires. The hum (which is worse on the "phono" select setting) is still audible on the headphone jack.
  • Onkyo Master
  • 19,396 Answers
That is probably a short inside the unit or a blown capacitor.
By the way your unit should be still under warranty, Onkyo covers one year factory warranty.
Call them by ringing the number listed on the user manual.
Posted on Nov 08, 2008
  • Ginko
    Ginko Nov 08, 2008
    Your model will be repaired for free by Onkyo. If for some reason the warranty is not valid, then you can purchase a warranty extension for a small fee.
    Click to contact them, you can use this form : Contact Support
    Or contact them at Upper Saddle River, New Jersey, by calling
    Tel: 201-785-2600 |
    800-229-1687
    Fax: 201-785-2650
    Hours:
    M-F 9am-5pm ET
    Product Support Team Hours:
    M-F 9am-8pm | Sat-Sun 10am-4pm ET
    If you live outside US use the wabsite homepage to find the contact:
    INDEX | ONKYO Global Site
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
Connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Aug 28, 2009 | Onkyo TX-SR705 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
The output to the front left channel is low
Try adjusting level calibration for the front left speaker under setup. This should solve your problem.
Mar 11, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Mar 04, 2009 | Onkyo TX-SR705 Receiver
Receiver - onkyo tx-sr606 problem - in the setup menu screen, option 2 "speaker setup" isn't highlighted to select like the rest. I am setting up new speakers and want to adjust the dB on a single speaker,...
if the speaker settings are deactivated, there is no other way but to reset the receiver back to factory settings. press and hold down vcr/dvr and then press standby. you will the word reset and that should activate your speaker set up again. hope this helps. ^_^
Dec 06, 2008 | Onkyo TX-SR606 Receiver
Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
May 21, 2008 | Onkyo TX-SR605 Receiver
My onkyo tx-sr705 produces a humming noise out off all the speakers when no audio is played
I found the source of my hum. I have Direct TV HD. I found that going into the menu settings (Direct tv HD Receiver) /Audio/Sound Effects and turning that option off, I was able to rid myself of the annoying hum. The option has something to do with keeping the audio settings from channel to channel, while it is changing you hear dead air except for the hum. Nice and quit now. Love this receiver!
Mar 06, 2008 | Onkyo Audio Players & Recorders
Onkyo TX-SR505 Receiver Logo
163 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
