Question about Olympus m:robe MR-100 Digital Media Player
M:robe my m:robe switches on and off fine the first time i use it after charging it. however the second time i go to switch it off, the touch screen stays alight and doesnt go off until the battery goes dead
0 characters
1 Points
Ipod Touch wont turn on
Your iPod has been working fine and all of a sudden it won't turn on. Not sure why? Before you rush to your nearest Apple store, try these easy-to-use, at-home solutions for fixing your iPod.
Check the Hold switch to see if it is off. Located on the top or the bottom of the iPod, when it is in the "on" position you will see an orange patch of color. Slide the switch until the orange coloring disappears. Try to turn on the iPod. Make sure the battery is fully charged by connecting your iPod to your computer's built-in FireWire or USB port or into an electrical outlet using your Apple iPod power adapter. Note: iPods without a click wheel cannot be charged using a USB port. After your battery is fully charged, try to turn on the iPod. Reset your iPod. iPod Shuffle: Disconnect iPod Shuffle from the computer if connected. Move the power switch to the off position. Wait five seconds. Move the switch to the play in order or the shuffle position. iPod Touch: Press and hold the Sleep/Wake and Home buttons together for at least 10 seconds until the Apple logo appears. iPod Nano (all generations), iPod Classic, iPod Mini: Turn the Hold switch on and off. Press and hold the Menu and Select buttons at the same time until the Apple logo appears, making sure to not touch any part of the click wheel. This should take about six to eight seconds and may need to be repeated. If your iPod still won't turn on, check the following: Make sure the iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard and iPod, and try again. Double check that you are using the FireWire or USB cable that came with your iPod, and that it is in good condition. Try the built-in port of a different computer.
iPod won't turn on
Mar 01, 2013 | Apple iPod touch
Ipod touch will not switch on fully charged left on docking staton all day swiched off with docking station
how many times have you charged it
Ipod batteries have a lifespan so they can only be recharged a certain ammount of times before they need replacing
if it will turn on with a charger either your battery is completely dead or the battery connections are loose or faulty
hope this helps
Jan 03, 2012 | Apple iPod touch Second Gen (8 GB,...
My ipod wont stay charged
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off. -hope it helps owner of i pod nano and I pod touch.
Dec 30, 2009 | Apple Mini IPod
Can't get settings of my MP4-touch right
my mp3 player touch screen is not responding to the touch movement ever since i pressed calibrate in setting
Sep 30, 2009 | Digital Mind Corporation iQ Sound...
Missil MV 3308-Charge Time?
Keep it on charging for 30 minutes to one hour. (It depends on battery). Make sure when putting it on charging, turn its power switch to ON position.
Jul 06, 2009 | MP3 & Digital Media Players
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
M:robe 500i doesnt respond!
The basis for the camera is it is touch screen and if your friend sat on it could say that that was one big touch (butt touch). What that probably did was over touch the touch sensor which screwed up the whole camera. The only thing I can say to you is you definitely have to send it in to a specialist........GOOD LUCK!!!!
Aug 31, 2007 | Olympus m:robe MR-500i MP3 Player
Scratchy music
Hey, sorry you havn't received a solution for your m:robe till now, you've probably already fixed the problem. But if not, I'd suggest taking it back to the store that you bought it from, then they can send it back to the 'Customer support centre'. I had the exact problem happen to me and I just had it sent away, it came back fine. Hope that helps:)
Sep 13, 2006 | Olympus m:robe MR-100 Digital Media Player
Olympus m:robe MR-100 Digital Media Player Logo
23 people viewed this question
Top Olympus MP3 & Digital Media Players Experts
 Mike M
Mike M
Are you an Olympus MP3 and Digital Media Player Expert? Answer questions, earn points and help others
