-   My printer printers but the memory buttom is flashing and it is making that annoying clicking sound. What's up-   maryd1
Jan 02, 2009
-   I have the same problem. Would love to know the solution, if anyone has it. thank you.
-   msbehavior
Jan 01, 2009
-   My canon mx850 also is plugged in, connected with a 9.8 ft. high speed usb 2.0 device cable, and does not respond to printing command from my dell inspiron laptop 600m. Instead, it makes a clicking sound. The In Use/Memory button also flashes. On the laptop it says that the printer is offline and to make sure the printer is connected and the power is on. They are.
OMG! Mine was also plugged into the phone jack at the back of the computer. I was on my way out the door to buy another printer! Thank you so much to TreasonGM for fessing up so that I could fess up also :)
I had the same problem. I had moved my printer and when I hooked it all back up, there was an annoying clicking sound, the "in use/memory" light was flashing and there was no communication with my pc.
This is a tad embarassing, but if it helps someone, so be it lol. I had plugged everything in without looking.... my usb cable was plugged into the phone jack >.<.
Check all your connections.... then check them again ;)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
Media (paper or card) will not print from tray 1. The roller does not turn so does not pick up...
(More)
Media (paper or card) will not print from tray 1. The roller does not turn so does not pick up media. It was printing fine from tray 2 before the red light came on and locked the printer. It was previously printing text OK although it was making some noise whilst doing it but when I printed text + artwork on same document it would put a border line around the artwork. Panel has been going blank for some time but was not showing any fault at any time.
No xerox and scanning is working but printing is going on. Display : scanner error no 5 turn off...
(More)
No xerox and scanning is working but printing is going on. Display : scanner error no 5 turn off then on
the small screen shows "wrong cartridge". I printed some pages with a new black ink, and...
(More)
the small screen shows "wrong cartridge". I printed some pages with a new black ink, and then gone down. Changing the black ink does not solve the proble. What I can do?
