Question about Epson Stylus CX4600 All-In-One InkJet Printer
Epson cx4600 tubes are clogged
The only color that will print is yellow. How do you get to the tubes to clean them out if they are clogged with dry ink?
  • 2 more comments
  • pre3bllr Nov 09, 2008
    Thanks, but I put in 4 new cartridges and I've run the head cleaner program several times and get the same results. The printer is about 4 years old and not covered by a warranty.
  • Anonymous Nov 11, 2008
    SAME problem, just called this number 562-276-4382 and supposedly they are going to replace mine free of charge? There must be a catch here?!?
  • madrake Dec 04, 2008
    I have had the same situation. Cleaned the heads numerous times; replaced/recharged the cartridges. Called tech support at the same number above. They acknowledged that it was not an ink problem, but a hardware problem. BUT, they would not even entertain the notion of replacing the unit (3 years old), simply told me they'd give me a repair center name or refer me to a "customer loyalty" site where they'd gladly sell me another one at a reduced price! No thanks. Sadly, Epson has lost a customer.
  • ruthkronthal Dec 06, 2008
    printer has not been used in over 1 year. put in all new cartridges and cannot get it to print. connections are correct and no software problems. help!!!
    Master:
  • 568 Answers
Hi there
first you can try cleaning the heads of the cartridge with the software which has come along with epson this will solve your problem if dont then please change the cartridges or call epson service center they provide u onsite warranty
Posted on Nov 08, 2008
I just installed a new black ink but it doesn't print black, only printed colors. I thought the ink was a defect so I changed another new ink but it is still not printing. Now, the color stopped working as...
your print heads might be clogged. clean it the hardware way. not the software way. to do this, simply buy a print head cleaning solution for Epson Printers. now pull out all your print cartridges and put a small drop of cleaning solution to the pin-like plastics in the base where your heads are seated. drop and drop cleaning solution to dilute clogs. you can use syringe to sip out the solution from the area. after this hardware cleaning, do a software cleaning through performing a cleaning print heads in the epson tools under maintenance tab
Oct 15, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson CX4600 printer - will not print color at all
no it should work at it is. if you installed the plug and play printer driver. have you removed the protection tape from the inc tubes?
Oct 12, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Lines in picture when printing
In the print queue there is an advanced tab that takes you to see how much ink you have etc. Go to the maintenance tab and select the cleaning option. Be aware that this uses up a lot of ink doing this. But once you have done it check the nozzle printout to see that it is continuous in its printing on all colors. keep at it till it is.
To prevent this from happening in future keep the printer on Epson dont say that turning it off can cause the ink to solidify in colder weather.
I have come to leaving mibe on 24 hrs a day or taking the cartridges out and then printing a pic till all color is used fromj the reservoir. This has kept my EPSON 90 going for 10 years my Epson A3 died within 3 years from clogged jets
Sep 01, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Printer is not printing text
If the printer was unused for a week or 2 the print heads are clogged with dried up ink. You can use the maintainance tab for the printer for cleaning and nozzle check or the program below. I have been using it for several years.
This is a utility to manage your ink. Gives an accurate count of how many ink shot are left in each cartridge. The printer just told me I need a new magenta but this program says I have 13% left. It also has sepparate routines for cleaning the black and color (unfortunately not individual cartridges) and a powerful clean cycle when they are really cogged.
http://www.ssclg.com/epsone.shtml
Jul 17, 2009 | Epson Stylus CX4600 All-In-One InkJet...
I bought new cartridges for my Epson Stylus CX4200 All-in-One, but the yellow and Magenta barely print. I have run the head-cleaning program on the computer, the one with the colored lines, and it...
Use "spet" (tube only). Add flexible pipe (cut from oultet pipe of head cleaning mechanic). Connect to nozzle. Fill tube with cleaner. Move head to parking position. Do suction from outlet pipe of head cleaning. It's the safely way to clean print head manually.
Jun 21, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Changed all ink cartridges, now only black and blue print
Sounds like your printhead is clogged. Since it isn't removable on this printer the following is a last ditch somewhat messy possible fix.
Here is the procedure that got my CX4600 printer working again:
Symptoms: head cleaning made the test pattern get worse instead of better, until I got no test pattern at all.
1. Unscrew the service panel door on the back of the unit to expose the waste tubes.
2. The direction of flow is "down from the TOP tube, into the plastic elbow, out to the RIGHT tube that goes to the waste repository".
3. Disconnect the plastic elbow from both tubes.
4. Clean the elbow using a paper clip and peroxide until it is completely unclogged and clean.
5. Get a waste receptacle, such as a small cup or something to catch the ink, and place it under the TOP tube. You will probably have to aim the tube with your fingers or a pair of pliers into the cup. The waste is going to spray out, possibly spatter if the waste has become hardened in the tube, so make sure you're doing this somewhere that you can clean up easily.
6. With the waste tube aimed at the cup, hold down the "ink" button on the printer until the cleaning sequence starts. The sequence will take about 20 seconds and blow the tube out in spurts.
7. If stubborn, you can loosen the junk in the tube using some peroxide - it doesn't take more than a drop from the end of a q-tip to start eating away... give it a few seconds to work itself upwards into the tube. Massage the peroxide up the tube with your fingers for more effectiveness.
8. Run the cleaning cycle one or two times to make sure that there is either air or nice wet ink coming out, but no more solid waste.
9. Reassemble
10. Connect CX4600 back to your printer, and print a test pattern... perhaps one more cleaning... should be fine.
Also see this website:
http://www.fixyourownprinter.com/forums/inkjet/23861
Jan 09, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus Printer CX4600
I don't know if this will work on an Epson, but it does on Cannon. The pads on the cartridges or the ink jets in the printer head may be cloged with dry ink. Get some Q-tips and rubbing alcohol (water is a poor substitute). Take out the ink cartridges and touch the pad on the bottom with a Q-tip (one for each color). If there is color the cartridge pad is OK. Take a fresh Q-tip dip it in rubbing alcohol and GENTLY rub the little holes on the bottom of the plastic box the cartridges go in. Thse are the print head jets. You should see color. You may need to clean it a couple of times if the ink has dried down into the jets. It is OK to have the Q-tip pretty wet, but not dripping.
Hope this helps
Dec 03, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Paper comes out blank
epson cx4600 prints blank paper replaced ink cartages .same problem
Dec 02, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
May 05, 2006 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
159 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
