I get an error message the connection to the program engine has been lost or terminated the program will not close and restart if you experience any problems contact webroot support at http:/www.webroot.com/support/.
Error message connection to the progam engine has been lost or terminated
Posted on Nov 20, 2008
No sond
Posted on Nov 08, 2008
Status 0x00000e9
Many of the problems caused by programs lead to the emergence of the messages that come in shape
A fatal exception XX has occurred at XX.
Often occur, because the program on the problem of improper code required Processor Processor you make improper operation. Thus Windows displays this message to tell you so and ask you to tell him what it must do. In fact, these kinds of errors do not escape them and often lead to the closure of the program or you may have to restart the Windows operating system as a whole and therefore you will lose any unsaved data before, and you models for these errors.
He noted that in all the solutions that Snordha here we'll use the letter A to represent the floppy drive and the letter C to represent the hard drive that contains the Windows system device and the letter D to represent the CD-ROM drive, and that all the messages and solutions applicable to Windows XP and Windows Me unless stated one only.
Message:
A fatal exception 00 has occurred at XX
Meaning:
This error occurred because the processor tried dividing the number to zero which is the correct thing is sporty and therefore this letter appeared.
Solution:
Close the message and try to continue to use the program, if you can not close the program and then restart it again, or restart your computer if necessary College.
Message:
A fatal exception 0C has occurred at XX
Meaning:
This error occurred because one of the instructions stored within a certain part of memory called the stack (which parts of memory are reserved for programs to deal with the equipment and devices) tried to use portions of memory outside the specified part
Solution:
Try closing the program and restart your computer.
Message:
A fatal exception 0E has occurred at XX
Meaning:
This error occurred trying to access the data processor located on the Page page of memory RAM or virtual memory Virtual Memory, but discovered the absence of the page, or that the data has been improperly accessed.
Solution:
Close the message and try to continue to use the program, if the program can not switch off and then turn it on again, or restart your computer if necessary College.
Message:
A fatal exception 13 has occurred at XX
Or General Protection Fault
Meaning:
Fault of the same quality as previous mistakes, but did not specify why.
Solution:
Close the message and try to continue to use the program, If you can not do close the program and then restart it again, or restart your computer if necessary College.
All previous mistakes are supposed to occur at intervals spaced opposed, if repeated occurrence tried to determine when those errors occur, if they occur while the program is running, you may be able to solve the problem, remove and then reinstall the software again, or get a version upgrade him.
If you can not link between the error message and a program may be the reason why a file from the Windows system files or one of the device drivers Device Drivers, and test it restart your computer in the security mode Safe Mode, if you do not see the message usually be the cause of one of the players devices Thus you can access the latest version of the drivers in your device through the companies that produce them site on the web, and if the message persists often will be a problem in the Windows system itself, and therefore you will need to re-set the Windows system again.
Message:
System busy and appear on a blue screen
Meaning:
This message appears with the nature of the error usually as stated in previous communications with the program said that the cause of the problem is the system may be Windows itself, and ask you to wait until the system becomes less busier.
Solution:
Restart your computer, and if the error is repeated several times do to deal with him as we have seen in previous communications solutions.
Jun 20, 2013 | Computers & Internet
Error messages appear when scanning from glass to macbook.
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error message when opening quick cam
You need to uninstall your camera
restart and then reinstall the cam.
This should help
Jan 11, 2009 | Logitech Webcam
Webroot spysweeper dead
Uninstall it and remove all registry keys and then reinstall it.
Dec 01, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Connection to spy sweeper engine lost or terminated
If you were experiencing a " The connection to the Spy Sweeper enginewas lost or terminated" error, or any other error messages, then pleaseupdate your software to the latest version of Spy Sweeper, ver.5.2.3.2125.
Good luck.....
Jul 28, 2008 | Computers & Internet
Spy sweeper will not work
unstall it all
download new verison renetr keys dont use cd
Jan 19, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Error message
This is a software error message. This model of scanner actually holds a file set ..not just one file. it is likely you are using a program to download your inventory list or similar, and the files have been lost (usually by leaving hte battery out too long).
A SKU is another name for an item number.
It is quite unlikely this is a problem with the hardware itself.
Dec 25, 2007 | Symbol LRT3800 Portable Terminal
The connection to the spy sweeper engine has been lost or terminated. Sky sweeper will now close and restart
CLEAN INSTALL needed here.
Try un-installing after the un-install, shut down completely for at least 30 seconds, and then restart. This releases any "Locked files" for deletion.
Then do a search in 'all files and folders' - search for both Weebroot and then Spy Sweeper, with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those files found.
You should do this search and delete whenever you un-install any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
BEFORE RE-INSTALLING Spy Sweeper
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling.
Dec 09, 2007 | Webroot Spy Sweeper (spysweeper) for PC
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
