Question about Sony KV-T29CF1 TV
No picture And only centre 3rd of screen, shuts off automatically
Sony Kv T29SF81 when You turn It on screen Shrinks and gets smaller until only centre 3rd of screen remains and then Shuts off. Took back off and adjusted the one of the KNobs/pots and managed to stop screen from shutting off but only get centre 3rd of screen and its green thinking it may be a faulty power supply. have checked main board and cant find any dry joints. I am an electrician but im completely lost and i have no knowledghe on tvs can you help
    President:
  • 3,130 Answers
It a problem in the vertical sweep circuit my freind. It could be the vertical IC, a capacitor thats bad the B+ sweep supply, or a bad connection on the board, but my moneys on the first, a bad vertical output IC. if you lug the thing into a repair shop it should not cost you over 125 to 150 bucks. if you have solid state serviceing as well as soldering experience you can get a service manual and find the vertical output IC and replace it. You stated you had no electronic experience on TV sets? Play it safe and let a pro assist you with this repair. Good Luck Please dont forget to rate this thread.
Posted on Oct 23, 2006
The Tv screen is much smaller during video games than what it is during Movies. Please Tell me how to adjust my screen size.
Movies are shown at a higher resolution than games. That is why the picture is smaller with games than movies. If you turn the Auto Picture Size off, you can set lower grade video to a larger screen size but you will lose quality.
Hope that helps.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I tune into television channels sony kv-t29sf81 television please?
press menu,setup,select cable, then auto program,enter......hope this helps....
Mar 12, 2010 | Televison & Video
Hi...I have a problem with my Sony Trinitron 29
the power supply section should be resoldered....must be loose contact..in power section...
Jan 26, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Only the sound comes in my tv no picture at all . When i switch it on the sound comes over but no pictures.any suggestions please?
you have to turn the screen control up a bit.there are 2 conrols on the flyback transformer,top one is focas bottom one is screen,turn it up 1/8 turn turn set off then on.repeat this until picture appears(if you turn it up too much picture will be to brite with lines and will shut off) if it shuts off just turn contron down a bit then restart it.
Sep 24, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
After a few minutes picture shrinks to single line on screen and then powers off
Since the set works initially, there are likely poor solder connections at the vertical IC. If this is not addressed soon, the IC will fail and need to be replaced. The vertical IC is a small flat IC with about 11 pins or so that may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace teh IC. Feel free to post the marking here so I can verify you have the correct one.
Dan
Jul 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
16:9 Enhancement (KV-36HS510)
Should be a choice from Auto to on ,then on to off......
Consult owner operator manual or download from sites / search
like Free Sony TV manuals.com .....
Dec 03, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
SCREEN GOES BLACK AFTER 1 MINUTE
In electronics dust has nothing to do. cleaning will not solve your problem your problem is due to trouble in vertical section. mostly it is due to electrolytic capacitor in vertical section is defective.it is common problem. also check supply to vertical section. "THE SCREEN SHRINKS TOWARDS THE TOP OF THE SCREEN FOR A FEW SECONDS BEFORE THE PICTURE TURNS UPSIDEDOWN THEN TURNS BLACK." is called fold over. regards thanks
Sep 12, 2007 | Sony KV-32S42 32" TV
Screen shrinks to 10 cm horizontal line
Yes, you are correct. Usually what I find in a set like that with that symptom is that the solder joints have cracked and come loose on the vertical output IC. That is the IC which drives the yoke coils that spread the picture up and down. If you have soldering experience then you can locate this IC and resolder its pins but if you have never worked on PC boards then have a qualified tech handle it for you. This is a very easy thing to repair so it should not cost too much.
Aug 06, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Jun 28, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
