Question about Speed Queen AWS52NW Top Load Washer
Speed Queen doesn't agitate.
Where can I find detailed instructions on changing and adjusting the belt on my top load Speed Queen washer..
  • jerrybee38 Jul 28, 2010
    Washed a load did great . Next load, won't agitate.
  • Anonymous Mar 26, 2014
    How do you remove the Speed Queen LWS21NW agitator ?
Can i see solution that ziobob got on nov.08 2008
Posted on Dec 02, 2008
Repair a belt on a washing machine for a speedqueen
Remove the front panel by removing the three screws at the bottom of the panel and then tilting it up to unhook it at the top. Make sure the machine is disconnected from the electrical power - not just switched off but unplugged at the socket. Look for the belt between the electric motor and the main drive pulley of the agitator and also locate the belt tensioner which is a small pulley pressing against the belt under tension of a spring hook onto it. Pull and keep the tensioner away by hand to allow the removal of the belt starting at the motor pulley. Replace with the new belt by starting at the agitator pulley. Keep the tensioner pulley out of the way until the belt is fitted on both pulleys and then allow it to settle against the belt again. Do not adjust the spring tension and buy the correct belt from speed queen as it requires a graphite type belt. An ordinary vehicle v-belt will not work - repeat will not work. Replace the cover by hooking it in first at the top and then replacing the screws at the bottom.
Oct 19, 2014 | Speed Queen Clothes Washer Agitate & Spin...
Fix agitator on a speed queen awm290
Is the drive belt in good condition?
Does the machine spin dry?
Is there water leaking from the bottom?
I suggest the gearbox needs to be replaced. Another sign is if the machine is noisy when it is washing (agitating)
Jul 04, 2014 | Speed Queen AWS45NW Top Load Washer
How do i take agitator out of speed queen awn412 washer
To remove the agitator all that ya need to do is grab the bottom edges of it and pull it straight up and out..if locked onto a hub under it and is just held to that hub by several tabs
Gene
Aug 25, 2011 | Speed Queen AWN412 Top Load Washer
Oil/grease leaking into tub. Speed Queen AWM492W top load washer. How to fix?? Thank you.
Check to see if the oil is coming from under the agitator. If it is replace the transmission. If it is not check to see if there is a grease spot inside the was tub.
Dec 29, 2010 | Speed Queen AWS75NW Top Load Washer
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
My speed queen washer made a high pitch noise when spinning. i took the front off and saw the belt was almost cut in half. how do i replace it?
Easy,It just slips over the fluid drive after disconnecting the link to the spin solenoid, then on to the pump pulley.
Adjustment is made by the motor mount.adjustment bolt.
Good luck.
Feb 23, 2010 | Speed Queen AWS52NW Top Load Washer
Will not start washing process
Is the belt broke?
If not, will it spin it you put it in spin mode?
If it spins, but not agitates, the transmission is locked up in agitation and needs replaced. This is a major undertaking.
Dec 12, 2009 | Speed Queen AWS51NW Top Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Speed queen top loader
You should be able to get a replacement agitator from partselect.com or repairclinic.com. look on line for an agitator however How old is the washer, would you give me the serial number.
T
Jul 27, 2008 | Speed Queen AWS44NW Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
384 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
