Question about Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000
My black and decker leafhog blower/vac smells like something is burning
My leaf blower at times has smelled like there was something burning inside the housing. Recently, the plug affixed to the housing, started to turn black and eventually sunk into the housing. I took it apart today and changed out the factory plug set-up with the male end of an extension cord. Amazingly, i got it all back together and the blower works when i tested it! The bad news is that i can see what looks like sparks through the vent holes in the housing of the blower. I am not sure if they are actually sparks, but it does not look good. Any suggestions? Thx.
  • 2 more comments
  • steveheld Nov 09, 2008
    Same exact problem. On of the prongs broek off and melted down a portion of the extension cord. I hate to throw this out and would be interested in repairing the unit. Assume that a professional repair would cost twice the purchase price.
  • Anonymous Nov 09, 2008
    my leaf hog did the same thing. started losing power and i see the aprks too. smell like **** too?
  • hsinger Nov 22, 2008
    same problem here, it melted the female plug. I was looking to find a service manual online to take it properly apart (and then be able to put it back together).
  • canarycat Dec 27, 2008
    I had the burning smell and sparks occur a few weeks ago but I haven't tried replacing the plug yet. One prong retracted itself into the housing and became wobbly, and the blower won't work at all
Black and Decker has issued a recall notice for Type 1 BV4000 because "a loose connection between the unit and an extension cord can create heat, posing a possible fire hazard" Says to STOP USING and call 1-866-853-2138 to arrange for free repair. (Found info by Googling "Black and Decker Leafhog", navigate to Black and Decker website and click "Important Safety Recalls" button at bottom of page.)
Posted on Jan 27, 2009
Check the repair solution I gave under "My blower stopped working", since yours will stop also before long.
Posted on Aug 09, 2015
My Black & Decker electric leaf blower/vac stopped working is smelling. What could the problem be?
In order to assist you please provide the model number, it is required to find the appropriate information for your device
Jan 20, 2017 | Garden
My leaf blower was working fine and then all of a sudden it stopped working
Try a different outlet, maybe the ground fault interrupter tripped on the circuit.
Sep 12, 2016 | Black and Decker USA Black & Decker LH4500...
Electrical burning smell
I had one like this. The problem is probably something wrapped around the blower. You may have injested anything from string to a piece of plastic.
Sep 01, 2014 | Toro Blowers Rake and Vac - Electric...
My black and decker blower bv2500 slows down and has burning smell
gas or electric ???
gas, check for a plugged exhaust and learn how to mix your fuel correctly
electric, throw that thing away
Aug 14, 2014 | Black & Decker Black and Decker...
I need to get a replacement power switch for a LH4500 blower/vac. Any suggestions ?
Well, B & D only offer the run of the mill parts for this model.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=LH4500&selectedType=17359
These guys only have a selection of general parts also. Sorry. Techs consider these tools "disposable" and even the manufacturer and parts suppliers treat it as such.
http://www.ereplacementparts.com/black-and-decker-lh4500-amp-leafhog-blowervacuum-parts-c-4167_9502_9546.html
Jul 03, 2011 | Black & Decker & Leaf Hog Blower / Vacuum
Older leafhog don't know how to change over to blower instead of vacuum model Bv2500
Remove the vacuum tube completely from the bottom of the machine and make sure the impeller cover closes completely. Remove the collection bag off of the blower outlet. Now attatch the blower tube to that outlet on the blower. Done.
Dec 07, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
I have a BV4000 Type 3 120vac-60Hz 12A Leafhog. I had been using it, had shut it off and it would not start again. There was no noise and no smell like getting hot or something. It is two years old and has...
first check your sparks plug, if it was never replaced it needs it. next check your air filter, if its clogged and dirty it needs cleaning. let me know if you have any questions about my answer or if these arent the problems, thanks
Nov 04, 2009 | Black & Decker & Leaf Hog Blower / Vacuum
Black and Decker leaf hog, worked fine last use.
I posted this solution on another similar thread, but it may pertain here.
I have this unit. Mine stopped working today after being warm on the handle the last few uses. I opened the unit up (torx 15) and smelled, then found that a fused wire coming off the motor had burned/melted/separated at a plastic plug right inside the handle. I'm not sure if it had anything to do with it, but in this same compartment of the handle there was an anti-theft strip floating around. I called BandD and they said the BV4000 type ONE has been recalled. http://www.cpsc.gov/cpscpub/prerel/prhtml07/07005.html
Jun 10, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
LeafHog bag tear
Found the bag on a replacement parts site:
http://www.ereplacementparts.com/black-and-decker-bv2500-type-high-performance-blower-vac-parts-c-4167_9502_9507.html
Feb 09, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Black & Decker Leaf Hog 12-AMP Electric Blower/Vacuum #BV4000 Logo
1,674 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
