Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Samsung dlp hl-r4667w picture/sound keeps freezing and restarting after a few seconds
I'm looking for some advice on what I can do to fix my DLP tv. I have a Samsung HL-R4667W.
The everything comes on and works for about 2-3 seconds, then it freezes and restarts. It does this nonstop until I pull the plug. There is power staying consistently to the lamp. (even when the screen shuts down, the lamp stays on bright) Both fans are also running strong not shutting down during the screen restart.
There is a little blue switch in the back where the lamp goes in and out. I made sure that stays down with some tape. I also pulled the thermostat wire out while the tv was running and it shut down because of that.( I think it tells me that the thermostat is working?)
Any help would be greatly appreciated!
Thanks,
Eric
  • 5 more comments
  • Anonymous Dec 23, 2008
    My hl r4667w dlb tv started acting funny last night. It the image would lock up but the sound would keep going. I though it was the cable box but now realize that it is the TV. I'm at the point now where the screen stays locked up or has green and purple bars running down it. The sound continues to work. The TV then stays locked up for about 30 seconds then shuts down only to do it all over again. I can not turn the TV off unless I unplug it.
    the TV is about 3 years old.
    any suggestions would be appreciated.
  • alisaallen Dec 25, 2008
    my hl-r5067w is doing the same thing. we just replaced the lamp and that is not the problem. any solutions?
  • saslazzaro Feb 23, 2009
    exactly the same as the original post, same model
    sorry, not the same model. mine is hlr5067w
  • ericwpierce Apr 07, 2009
    same thing going on with mine. did you ever find a solution?
  • cashbeck Apr 10, 2009
    I have a 50" Samsung with the same problem. Sometimes it starts fine, but usually it locks up shortly after starting it and you can't turn it off unless you unplug the power. I can't find any help how to fix this problem and of course I am still covered under my Circuit City warranty, except they just went bankrupt! That's my luck!! Has anyone found a solution?
  • Anonymous May 10, 2009
    I have the same friggin problem!!! what is this thing?!?!!?
SOURCE: RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Posted on Apr 05, 2008
Slinteriors
  • 8617 Answers
SOURCE: I have a HL-R4667W DLP
usually when all the leds are flashing it means there is a defect with the lamp. Try replacing the lamp
Posted on Apr 27, 2008
  • 373 Answers
SOURCE: Tv shuts off
can you go into the menu and rest it
Posted on Feb 10, 2009
ladywinn
  • 5138 Answers
SOURCE: screen goes black randomly during use and tv shuts off
check your capacitors cp150 114 120 if any of them is puffed up on top it is bad replace all 3 cap. 2200uf 1`6v and two 220uf 35v. also resolder FBT pinns.
Posted on Feb 20, 2009
jinxfactory
  • 4 Answers
SOURCE: tv was on and then
Sounds like your bulb went out. Is the warranty still in effect?
Posted on May 02, 2009
Green vertical lines,minor. flashing goodback ground pic good sound . i have samsung dlp tv model hl-r4667w
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Jun 11, 2010 | Samsung DLP HL-P5663W 56" TV
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
DLP HL-R4667W Resolution 1080
notice it states 'hdtv ready', not 'hdtv'! probably need a converter or upgrade module to get 1080p! read the 'gotchas' in the owners manual!
Good Luck!
Oct 08, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Bightness Change
It sounds like your lamp is going bad. The lamp part number is listed as "lamp code" on a sticker located on the left side of the set. Use this number to grab a replacement off ebay.
Dec 20, 2007 | Samsung DLP HL-P5663W 56" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
580 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
