I am doing a first time set up of a mx850 and just installed the ink , closed the cover and received an error m #6a00? looked in book page 131 and no mention of such #? please advise...Frank
  • romanx39 Nov 09, 2008
    can you help error message #6A00 ???? what does it mean? my first canon product and i am beginning to hate canon.
  • romanx39 May 11, 2010
    are you nuts. What a BS E - Mail . Did you give me a direct answer? Is this JUNK? What is EM 6A00?
By the way , your user guide stinks as well. And if I don't get an appropriate answer soon, I will go back to the site I purchased it from and post as much bad advertising that I can.
Posted on Nov 09, 2008
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
My canon pixma ip2000 lights flashing 7 times
LED Blinking in Orange:
Mx850 canon all in one. was working fine then the alarm light came on and screen shows error code 6A00??? have tired moving the ink cartrigde device, unplugged and pluged back in ... checked everywhere...
6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
Dec 31, 2010 | Canon PIXMA MX850 Multifunction Printer
Error 6A00
This link covers it in several posts.That code always relates to a paper jam,or an ink cleaning problem.All of it,you can do yourself.
Bob
http://www.fixyourownprinter.com/forums/inkjet/37440
Aug 09, 2010 | Canon PIXMA MX850 Multifunction Printer
Error code 6A00 comes up. Data line and power cord
That error means the purge assembly is not working properly. Could be a scrap of paper stopping it from cycling properly. The purge unit is the cleaning assembly where the printhead parks, it has caps that draw ink from the printhead to clean and a squeegee to wipe off the excess ink. If the printhead comes to the center, unplug printer and check on the right. If nothing there you probably need a shop repair.
Feb 15, 2010 | Canon PIXMA MX850 multifunction InkJet...
Error code 6a00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 14, 2009 | Canon PIXMA MX850 Multifunction Printer
Error 6A00,under warrenty
Hi
All the best
Solution 1:
Solution 2:
Solution 3:
Oct 14, 2009 | Canon PIXMA MX850 Multifunction Printer
MX850 ERROR CODE 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 05, 2009 | Canon PIXMA MX850 multifunction InkJet...
Model Canon MX850. Display error message 6A00. Turnoff and unplugged printer, replugged in and turn on with same result: error message6A00. What to do?
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 01, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MX850 printer. will not print and shows error code 6A00
Hi
Here is the codes
Solution 1:
Solution 2:
Solution 3:
Sep 23, 2009 | Canon PIXMA MX850 Multifunction Printer
jasbo
jasbo
