Question about Kenwood KDC-MP728 CD Player
Cd loading i'm having problem with my cd deck loading. Don't know where the reset button is located at. any suggestion?
  • bboy_beez Nov 10, 2008
    KDC-MP728 CD Player
    thanks, i found the reset button. However, the cd deck still won't load. The screen reads loading but spits it back out after a few seconds. Sounds like the motor is taking it in and running properly, but not reading. I bought it used. Worked fine for a few month or so, and just somehow stop loading cd. Radio and all works fine. Any suggestions? thanks again.
    President:
  • 624 Answers
Right next to the #6 preset button you will see a tiny hole. That is your reset button. Use the tip of an ink pen or something else as small and sturdy as an ink pen tip. Just push it in for about 2 or 3 seconds and your unit will reset back to factory default settings. Please be aware that this will also clear all the preset radio stations and the clock. So you will need to input those again.
A reset may or may not help with your disc loading problem. If you could tell me more detail about the problem I may be able to help. Do the motors run when you put a disc in to be loaded and it just doesn't take it in? When you put a disc in to be laoded, do you hear nothing, no motor running or anything? Or does the display just not move down to the proper place so you can load a disc?
There can be many reasons why a CD player won't load a disc, but the only way to have even a small chance at guessing would be with more detail. It normally takes the ability to look at a unit to determain what is causing it's failure. There is no substitute for having your eyes on it to see what it does and to check the things that need to be checked. Electronic troubleshooting is difficult at best when it is done over the internet without the unit in front of you. I hope you will be patient and bare with me while we figure out your problem, and please do not give me a bad rating without the opportunity to communicate back with you if needed.
I have over 18 years experience repairing Kenwood radios at an authorized Kenwood service center, so I don't think you could find any better help, but it may take a little work on both our parts.
Dave
Posted on Nov 09, 2008
How I can reset a Clarion MAX385VD?
The fist thing I can suggest you you is unplug any peripheral cables and memory cards, and reset the unit. To reset the MAX385VD, on the lower right side of the unit - there is a pin hole. Inside the hole is a reset button.
To access -bend a paperclip - then insert it into the hole. With the vehicle ON - Press and hold the reset for 5 seconds and then re-try.
Additioanally details find in Clarion MAX385VD_User_Manual
Hope this helps.
Jun 22, 2011 | 2000 Pontiac Grand Prix
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
Hi, I recently purchased a new Stereo deck and I like to remove the old Alpine CDE-7827 deck. My car is a 1995 Ford Thunderbird.
The original wires in the 95' thunderbirds are a pain, trying to figure out how to take out factory stereo and replace with aftermarket Sony cd player, have no clue because the wires don't match up, some do and they will load and unload discs but won't power up any suggestions...?!?
May 24, 2011 | Alpine CDE-7827
Won't turn on, is it in protection mode?
Is the immobilzor/ alarm light actuated? try resetting the deck, via the small pin head reset button located on the plate when deck is open.
Apr 07, 2010 | Sony CDX-M630 CD Player
Cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
Jan 06, 2010 | 2001 Lincoln LS
Cd won t eject from 2006 Ford Focus mp3 player Get eject error message How can I safely remove CD''
HI, either the deck assembly is jammed or, the load motor has failed. In this case, you will need to disassemble the entire set in order to retrieve this CD.
The actual loading deck(the part where the CD is located), is surrounded by a metal housing. the gear assembly is probably locked, due to this jam or failed load motor. This will also require a set of precision tools as well. if you find this a bit overwhelming, i suggest taking this unit to a local automotive audio shop. they can dissemble it and, retrieve the CD for a small price.
Jun 21, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
DN- S3500 Cd stuck
HI,
Please reset the unit for 4 hours by unplugging all the cords,even the power cord from the unit and then plug them back again after 4 hours.Now try ejecting the disc.Let me know the result.
Feb 10, 2009 | Denon DN-S3500
KRC-3008 KENWOOD
The "Reset" button on Model# KRC-207S is located between the"ATT" (attenuator) and the "1" button. It is a tiny hole. Insert the end of a pen or pencil into the hole and hold for a few seconds and the unit will reset itself. Hope this helps...
Sep 03, 2008 | Kenwood KRC-207S
How do you reset this deck
There is a reset button on the left front of the deck>
Feb 16, 2008 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-X590 ipod
Do you have a Ipod shuffle?
Is the deck on random?/shuffle?
Try pressing the small reset button on the deck, its small a small black button you would need a pencil tip to reset!
Hope it helps,
Don
Mar 16, 2007 | Kenwood KDC-X590 CD Player
Kenwood KDC-MP728 CD Player Logo
61 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
