Question about Procom ML300HGA Heater
Burner won't light
This is brand new, I just had it professionally installed. The pilot lights fine but when you turn the knob to light the burner the pilot goes out and you have to relight the pilot. I did this about 10 or 12 times and then it finally lit the burner one time and hasn't worked since. What is wrong??
  • Jigsaw Nov 08, 2008
    The pilot has been on for 2 days. It stays on fine.When you turn the knob past the ignite mode, it clicks and you hear the gas, then as you are turning the knob to ignite the burner the flame dies down and clicks off before you can turn the unit up. This unit has a thermosat so I checked to see (even though the pilot had go out) when you turn the knob up you can hear the gas hissing. So the problem in the burner you are saying?
    Thank you, I will call the tech on Monday.
  • 19,396 Answers
There is a termocouple that controls the pilot, when the termocouple is faulty, the pilot does not stay on.
Call back the technician.
Posted on Nov 08, 2008
  • Ginko
    Ginko Nov 08, 2008
    First ensure that on ignition you are holding the button long enough to warm up and keep the pilot on.
    When you are firing up you need to hold the button for some time, until the burner gets hot, or the flame will turn off, that is normal.
    If there is no way to start it even holding the button for five minutes, then the burner is faulty.
    In this case, the gas valve has a termocouple, that turn off the gas valve.
    When the pilot goes off it is often a faulty termocouple.
    Testing and replacing the thermocouple is not a job for beginners.
    You need to test the termocouple at different temperatures, and there are many safety issues involved.
    If there is a fault the job must be done by a technician.
  • Ginko
    Ginko Nov 08, 2008
    I told you.
    There is a thermocouple, when it is faulty it can cut down the gas, then when you reignite you have gas because valve is fine.
    A thermocouple is a device that is sensible to temperature, and when heated generates electricity. The electricity opens a electro-magnet controlled valve that keeps the pilot alive and the main burner opened.
2 Suggested Answers
SOURCE: Burner won't light
I left it off for a couple hours and it fired back up.
Posted on Nov 09, 2008
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
My heil furnance comes on but no hot air or air at all
see this causes and fix it. God bless you
o light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps: Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Oct 08, 2012 | Honeywell Icp Heil Tempstar Furnace Spark...
RHFE Rinnai 551FT gas heater is not working after 7 years
see this steps and fix it. God bless you
If there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below).
If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
To light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps:
Light the pilot:
Adjust the pilot:
Sep 30, 2012 | Heating & Cooling
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
I turned on hot water to take a bath, and it was hot. by the time the tub had filled the water was freezing. now we cant seem to get hot water out of anywhere. the pilot light is on. the knob is set to on,...
if I was a betting may I would say that this is a small water heater, what is the temperature set on, as the pilot light will be lit once the temperature is reached, but until then the burners will be lit. I would move the temperature knob and listen to see if I hear the burners kick on. Hope this helps Tim
Apr 17, 2011 | Heating & Cooling
PILOT LIGHT KEEPS GOING OUT.
If the pilot flame is weak, when the main burner is ignited, there can be enough 'whoosh' of air and gas to blow out the pilot. There may be a little of grit in the pilot valve jet hole restricting the flow, hence the weak flame. Try using a piece of fine wire to clear the obstruction. If that does not help the pilot jet will have to be unscrewed and cleaned with compressed air. Ensure the gas is turned off before attempting any maintenance.
Sep 13, 2010 | Reliance Water Heater #6-40-GBRS 40GAL...
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Burner won't light
Nov 08, 2008 | Procom ML300HGA Heater
Procom ML300HGA Heater Logo
51 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
