Question about Sony Ericsson w580i Cellular Phone
Sony w580i when i turn on my sony w580i the screen remains black.all side lights and keypad lights com on.i have tried another lcd screen but to no avail. any ideas ???
  • christian856 Feb 04, 2009
    the display is dark all other light are on but i cant see onything on the screen. waht cam i do. the One/Ornage shop say: Software or Hardware error. and this after 6 month. what a pitty. what can i do?
  • sammi69 Feb 18, 2009
    right were do i start firstly i am pest when it comes to taking mobiles apart so i learn by trial n error i had the same problem earlier i even went as far as buying a 580i 4 the bits. so i started removing the lcd but just thought id try pressing the ribbon cable connector a there it was my screen was back it has to be well pushed down, and cos the lcd is a bit awkward to put back it must move, the only other thing is a splice in the cable does the screen still power up but remain blank . hope i helped a likkle bit.
How to remove trojan virus in my sony ericsson w580i phone
Posted on Nov 09, 2008
I used an Led cleaner to clean the screen of my sony ericsson w580i now it is dim and streaked. Is there anything to clean it to remove this or do I just have a new cool screen display. I will probably...
There are some layers between the LCD screen and the Back light. It seems there are some remaining liquid in that layer. Try to remove the LCD carefully and clean the layer which is between the LCD glass and the Backlight.
Mar 08, 2011 | Cell Phones
Hey, I have a Sony Ericsson W580i, i dropped it on the floor the other day and now when i turn it on, its just a black screen, can i do anything to solve the problem? Thanks.
It's possible the lcd screen connection came loose. Try opening it up and re-attaching the lcd screen cable. There are tutorials on youtube that show you how to remove the lcd screen and re-install it.
http://www.youtube.com/watch?v=IMv0vYYthro
Oct 07, 2009 | Sony Ericsson W850i Cellular Phone
580i dosen't start
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank or it the LCD connector may have come loose.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Display Screen Replacement
I hope that helps you out
Aug 16, 2009 | Sony Ericsson K850i Mobile Phone
2 black horizontal lines across the screenon my w580i...
More than likely you will need to replace the LCD screen. This is the start of the screen going bad. If you have it under warranty still, try to get it replaced.
If not, a new LCD screen runs about 15 dollars shipped from ebay2.gif.
The LCD on the Sony W580i is snap to replace.
Sony W580i Displa Screen Replacement
Aug 14, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Black lines on screen
More than likely you will need to replace the LCD screen. I have seen it happen to people carrying it in the pocket.
The W580i LCD is really easy to replace. Probably one of the easiest I have ever done.
Sony W580i LCD Display Replacement
Aug 06, 2009 | Sony Ericsson w580i Cellular Phone
Display not working and the screen is all black...
You need to replace the LCD as you've already taken it apart you should be able to replace the lcd yourself
May 08, 2009 | Sony Ericsson w580i Cellular Phone
Screen of cell is not turning on or anything but keyboard is
You can take it apart and try to reseat the connector. If that fails to fix it then you will need to replace the LCD screen. A new LCD screen runs about 15 dollars shipped from and it is a pretty easy replacement.
Sony W580i LCD Display Removal and Replacement
Apr 05, 2009 | Sony Ericsson w580i Cellular Phone
My w580i went into the bath and the screen has blackened
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank. This happens when they get wet.
A new LCD screen runs about 15 dollars shipped from eBay and are simple to replace.
Check out the following link for instructions on replacing the W580i LCD display and links to buy the screen.
W580i LCD Screen Replacement
Mar 21, 2009 | Sony Ericsson w580i Cellular Phone
My Screen for my W580i is black, but side lights are on
This is most probably a software/firmware issue with the phone. Try updating the software with the Sony Ericsson update service.
http://www.sonyericsson.com/cws/support/products/updateservice/w580i?cc=gb&lc=en
If this doesn't work you will need to have it flashed with proper equipment,
Mar 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson w580i Cellular Phone Logo
287 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
