Question about Pioneer PRO-100 TV
TV picture shakey/blurry
My TV is shaky/blurry with a bit of a squeaky sound. And when I first turn it on the whole screen doesn't come on. The screen is in the middle of the TV for awhile. The red light also came on today and it wouldn't turn on at all. It took a couple of times to turn on. What can I do? Thank You, Rachael
    Scholar:
  • 68 Answers
Rachael, The Pioneer PRO-100 is a rear projection 51 inch TV of 1000 lines resolution. I do not know enough about the type of projection to answer this question. They use Liquid Crystal Display panels through which a powerful light shines, or Texas DLP micro-mirrors which reflect the light. As the deflection is digital in nature it does not `die' like a C R Tubed television. Are you saying now it won't come on at all, and shows the red light? I can only think it is like a projector and has fans to cool the lamp. To start with the fan may get squeaky due to a dry bearing (common problem). Eventually the fan will stop or not supply enough air and the lamp will overheat and burn out. They cost 250£ to 450£ to replace.(UHP mercury vapour lamps) In your TV it seems that something in the optics has bad distortion and de-focussing due to the overheated lamp. This could be much more expensive to put right.
Posted on Oct 23, 2006
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Blurry shaky pic
It sound like you have a leaky capacitor in your power supply, or video circuit, that is causing noise in the picture. I would have to refer you to a television technician in your area. This would seem like a simple repair. Leaky capacitors can become stable after they warm up.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 01, 2009 | Toshiba 50H81 50" Rear Projection...
My toshiba big screen tv is shaky and blurry
most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
Blurry picture
If the power to the tv was on when the power came back on it may have caused a power surge through the tv and could have knocked the allinment of the colour tubes out a bit you could try to reallin them via small screws on the colour tubes but you need the tv on an it can be difficult.
Jul 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 50H71 Projection TV
I would check the power supply and the tuner section. This sounds like the low voltage powers supply is going bad or that the tuner section might be going bad. Does the picture fade to snow? Also I would suggest that you let a TV Technician take a look at the TV to determine what is happening. Most likely it is the power supply.
Thank you,
I hope this helps,
Shuttle83
May 27, 2008 | Toshiba Televison & Video
Shakey Picture
bad cap, spray some freeze on it till it comes back and you will find the bad part.
Nov 17, 2007 | Toshiba 65HX81 65" Rear Projection...
Pioneer PRO-100 TV Logo
98 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
