Question about Sony SLV-N750 VHS/S-VHS playback VCR
  • OLDIE2 Nov 08, 2008
  • 10,594 Answers
Are you asking remote sensor in VCR or.... Photo Diode in remote control?
Posted on Nov 08, 2008
  • Shahid Electronics
    Shahid Electronics Nov 10, 2008
    Remote sensor is mounted on Front Panel Assy and complete board needs to be replaced.
    It is available in Part Store.
I bought an RCA smart tv and it was working fine until I picked up the RCA remote to change channels and now I get "no signal" on my TV screen. How do I fix this?
What was going on before you picked up the remote? Did the remote work OK to initially turn on the TV? Where you able to change channels prior to this issue? If yes, then maybe you accidently changed the source mode of the TV via the remote?
The source mode button chooses what signal you want to use for getting a signal transmitted to your TV (E.g., antenna, HDMI, etc.) If the source button is clicked to something that is not supported (E.g., Line1, or Line2, or Line3, or a particular source like the antenna option is not set-up properly to receive a signal, then you will receive a, "no signal" message".
Dec 14, 2016 | RCA Televison & Video
Remote sensor (thn122) not working, batteries changed, terminals cleaned
I have had this Oregon Scientific model RAR186 unit for years and it works great. The only issue I ever have is when the batteries need to be changed in the remote sensor unit (Oregon scientific model #THN122). It never fails that once I change the batteries that the unit does not send a signal to the base unit. I will often hit the reset button and change the channels on the remote sensor before I finally remember that you need to do the following to get the sensor to talk to the RAR186 base unit:
On the base unit (RAR186), hold down the CHANNEL and MEM buttons for at least two seconds.
You will then see a graphic appear above the channel number that shows that it is searching for the sensor.
Within a minute, you will then see the temperature displayed for the sensor showing that they are communicating.
This is buried in the manual that you probably discarded as did I.
Apparently, if your sensor is broken, you can either search to find a new sensor of the same model or also use the following sensors: THC138, THGR122NX, or THN132N
I have not needed to replace the sensor as once I found the instructions to reset the communication between the sensor and base unit, all was fine. Hope this helps someone. I wrote this instruction using a Sharpie on the inside cover of the sensor since you have to remove 3 screws to replace the AAA batteries (2) in hopes I will remember next time and not waste my time searching the internet and not find the answer. Good luck!
Mar 05, 2013 | Oregon Scientific Measuring Tools &...
Good evening.,i have the RCA TruFlat model number 20F424T. I'm trying to connect a converter box and I cannot get the tv itself to change confused either manually out with the universal remote. I...
your problem is likely the universal remote will not enter the menu and engage the auto program this set has--if it does and finds nothing either no signal or a bad tuner in the set.
If set has audio video jacks see if a DVD etc works on them--can always hook up signal to those inputs to bypass the problem.
Apr 28, 2012 | RCA Televison & Video
My will not work with the remote any longer. I replaced that. When I manually turn power on, it takes 3 or 4 times before coming on. Then, it will turn off after about 30 seconds. ANy ideas?
There is an infrared sensor inside the tv to receive infrared signals transmitted by the infrared signal generating light emittin diode fixed on your remote control. Either the sensor inside the tv or light emitting diode in the remote controller faulty, remote function will not work. For manual operation troubles, check the wall power socket of plug of the tv is faulty, loose contact etc.
Oct 13, 2010 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
CHannel stays on 9 and won't go up.
This sounds like a problem with the diode matrix which pre-programs channel 9 on the PLL code signals. Probably the "channel 9" switch that activates these diodes is bad, so that the diodes are activated all the time preventing the channel switch to do its work. You will need a schematic diagram and a voltmeter to check the logic signals in this circuit. Start witht he switch; does the switch voltage change when you toggle the switch? If not; switch is bad. If it does, the problem must be "farther downstream" with the diodes itself.
Jul 22, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
My tv set is nt tuning any channel
your electronic tuner in the set may need replacement.
Are you using a remote to change channels it may be the batteries in the remoter that needs to be refreshed.
Not a lot of detail here as to what model TV this is or what remote is used.
Jan 23, 2010 | Apevia X-TELSTAR-BL ATX Full Tower Case
How can you tell if the remote sensor on a tv is broken?
First you need to check if your remote is working. You can use a digital camera to do so. First place new brand batteries in your remote and then look at the signal diode (the small transparent bulb thingy at the top of your remote). If you press the buttons on your remote you should see the diode flash. If not then there are one or more bad components on you printed circuit board or probably open circuits.
Aug 17, 2009 | Philips Magnavox Learning Universal Remote
Sharp Aquos HDTV Failed to receive broadcast
I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
Mar 29, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Alesis m-eq 230 stereo equalizer will cut out after 1 hr
Your internal circutry is failing... it sounds like its happening after it gets warm, which may cause an old/cheap part (or parts, like capacitors) to fail inside. think about how long have you had these items and how much use they have had.  As always, thanks for using fixya
Dec 27, 2008 | Audio Players & Recorders
Toshiba 50A62 Remote Infrared Sensor
I have replaced these IR sensors before and it has solved the problem...they dont blow all the way..they just get weak......replace it.
Jan 25, 2008 | Televison & Video
Sony SLV-N750 VHS/S-VHS playback VCR Logo
106 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
