I recently purchased a blade MCX micro helicopter. It worked fine for a while but after i charged it and connected the bettery up to the helicopter it wouldnt work, im sure that thebattery still works.
  • mcmusica Dec 04, 2008
    I bought it also I have had the same thing happen and its left me pissed not sure if they are that good cause I hover for a bit turned it off by taking the battery out and when I turn it back on it stopped working and I was just hovering I did not crash or anything and now the power wont come on gonna get a replacement but it shows this heli is not that good if I had it for mins it flew once and then stopped working and I followed the instructions to the letter might be **** if it happen to more people it would be a great heli if it would not have stopped working for no reason cause all the batteries etc are new so this is not a good sign about this product if the power wont come on.
Be sure to have fresh batteries in your charger. If thats not it, be sure the controller is on before you plug the battery in your copter.
Posted on Nov 10, 2008
My Air Hog Black Ops helicopter blades do not spin. It is charged as lights on helicopter and controller work. I have tried setting controller to all 3 channels with no luck. Any ideas?
check over the helicopter first then hand controller
heli
could be the receiver chip or pick up on the helicopter
motor issue ?
didnt think it was direct drive .might be
have to chase a broken wire connection or other
if cogs or belts are used ..stripped or jammed or other
receiver
toast
Jun 18, 2016 | Air Hogs Havoc Heli Helicopters
My micro twister pro helicopter won,t lift off. all seems to be working fine
If it was the motor gear, the blades wouldnt be turning at all...some ppl are clueless :-/
Jan 03, 2012 | Toys
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
Hi my son just bought a Micro X Copter Alloy IV 4 channel, it worked at first but after just a few times it no longer will lift. The middle blades and tail blades are not getting enough power. It did not...
Maybe it is out of power an needs a charge? Also, if there is alot of pet hair, dust, and human hair, it could have gotten some in the axels in the blades causing it to spin slower, and could short circut the whole battery if you keep using it with the dust in it. I suggest taking all of the blades and axels and stuff off the main body of the helicopter and take all of the excess dirt and dust off. I hope this helped :)
Aug 22, 2011 | RC Micro X Copter Mini RC Helicopter
Recently purchased syma 107 w/gyro. Worked fine for a while. now it takes off, rises, then follds into itself, blades interlacing, then falls. I see nothing obvious wrong. It just falls, out of...
Your main rotor head broke. You should get a new one.
http://static.rcgroups.net/forums/attachments/3/2/5/2/4/1/a3813016-84-Main%20Rotor%20Head.jpg?d=1298131255
Mar 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
My rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
May 11, 2010 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
Tremendous machine vibration
Make sure the "connect buckle" is connect to the correct side, and not bent in the middle, it should be straight. If this doesn't help, new blades are sometimes different weights try to matching the weight of opposing blades you may even need to sticky tape a small weight underneath the blade to get them balance. Don't stick anything on to the top of the blade.
May 25, 2009 | Apache 3 Channel Micro Indoor Helicopter...
Rotors spin just a little
make sure that the blades are snapped into place and that everything is charged and then make sure the heli is on because if you crash it, it will automatically turn itself off and then make sure no hair is stuck on the bar that spins thats attached to the blades and then try it again
Dec 26, 2008 | Spinmaster Air Hogs RC Reflex Micro...
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
