Question about Emerson EWR20V4 DVD Recorder/VCR
Unit will not start or load disc
First the power light goes out after 2 seconds but unit is still on. Second, on screen you see the disc loading bar. When it gets to about 90% the unit cuts off. Third, when you press the disc load button, the tray comes out half way at the most and then goes back in. Fourth, the unit will not laod a VHS tape at all. Fifth, with unit "off", the fan comes on from time to time randomly (30 to 120 minutes between start-ups) 1. tried cutting all power , wait 30 min. , then reconnect. no good 2. tried putting in firmware disc that came with uint. no good 3. tried funai web site. no good before this crash, the unit had started to not want to load disc. had to load at times twice before it would read the disc. Please help.
    Problem Solver:
  • 5 Answers
Try opening up unit and using canned air and blow it out - sometimes simple dirt causes things like this While inside glance and see if you don't have some old tape or bits of labels that have come off and are anywhere inside that might be hanging the various working areas. Try using cd cleaning disk and vhs cleaning tape Without seeing this not sure what is causing it but may be something simple like the dust or pieces of label causing problems or the little rubber "tires" and other rubber components having gotten stretched out and slipping.
Posted on Jun 08, 2007
Toshiba REGZA won't play DVD. Shows "disc loading" then goes to wide screen mode, but then ejects the disc. Whats up?
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 17, 2014 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Simpson eziset 605 wont turn on-totally dead
Possible that the mains program controller unit is faulty. It is not ideal to buy a second haand one unless there is warranty as you could end up with a unreasonable bill. Check the main power to the prgram controller unit.
Jun 26, 2012 | Simpson Washing Machines
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
PS3 Discs Not Loading.. (Dvds, Cds) We Opened Up The PS3 And Checked The Drive And Cleaned The Lens And Dusted Off Everything Pretty Much And We Put It Back Together And turn it on Still Not Working Jus...
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
Rise of the lycans won't play
This will be a firmware issue with the unit if this is the only disc that wont playback. If the unit already has the latest firwmare installed (this can be checked by connecting a LAN cable to the back of your unit and accessing the menu) you will need to wait for the next firmware update to be released to solve the issue.
I would advise contacting Samsung where you are residing to adivse them of the issue.
Jul 16, 2009 | Samsung BD-P1500 Blu-Ray Player
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Won't Power On!
My brother had the same problem with his machine. On doing some research online I came across this site:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3390#results
It gave the following 2 solutions to the problem. The first one workedfor a while but then we had to try the second and this seems to havesolved the problem.
Solution 1
ssue
No Power or Will not boot
Solution
If the unit will not turn on and has no power:
  1. Verify that the power cord is plugged both into the unit and an electrical socket.
  2. If it is plugged into a power strip or surge protector verify that the power strip or surge protector is turned on.
  3. Try another power outlet.
  4. Unplugthe power cable from the unit, hold the power button on the unit downfor 30 seconds. Release the power button and plug the power cord backinto the unit. Try to turn it back on.
If the unit has power but does not boot into Windows:
  1. Turn the unit off and unplug the power cord from the unit.
  2. Hold the power button on the unit down for 30 seconds.
  3. Release the power button and plug the power cord back into the unit.
  4. Turn the unit on.
Solution 2
Issue
Recovery media and Restoring a system to factory load
Solution
Acersystems ship with eRecovery Managr, which facilitates the creation ofRecovery media (CDs or DVDs) so the system may be restored to theoriginal load in the event of unrecoverable issues.
How to Make Recovery Media
  1. Click on Start, then All Programs, then Acer Empowering Technology.
  2. Click on Acer eRecovery Management.
  3. If prompted to create a password, create a password and hint.
    Do not lose this password.
    If asked for a password, enter the previously set password.
  4. When the Acer eRecovery Management loads, click the button labeled Burn Disc.
  5. Click Create Factory default disc.
  6. Follow the instructions and put in the required Blank DVD or Blank CD media to make a set of Recovery Media Discs.
How to Recover your system from within Windows
  3. If prompted to create a password, create the password and hint
  4. When the Acer eRecovery Management loads click the button labeled Restore.
  5. Click on Restore system to factory default.
  6. The unit will restart and start the restore.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  7. At the eRecovery Management menu it will ask you how to restore.
    Click on the restore option you would like to use.
How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
We used the recovery from bootup version.
I hope this helps you.
Oct 20, 2008 | Acer Aspire L100 PC Desktop
Acer aspire l100
got a backup disc? you may have created one when you first got your computer?
Jun 26, 2008 | Acer Aspire L100 PC Desktop
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
PS2 not staying on
It's either a faulty power-pack (the boxy thing that is between the unit and the wall) or it's in the unit itself. If you know someone else who has one see if you can borrow their power-pack and try your unit on it. If the problem persists with the other AC unit then it is on the motherboard and will be likely unrepairable.
Sep 10, 2007 | Sony PlayStation 2 (PS2) Console
Emerson EWR20V4 DVD Recorder/VCR Logo
102 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
