Question about HP Computers & Internet
I have a Dell Desktop running xp, my sound works but when I tried to hook up my new HP Premium Stereo headset the mic refuses to record sound. In playback the Microphone is not even available to be checked.
  • charmling1 Nov 08, 2008
    nope I haven't tried that because it is brand new out of the box and my first and only one :)
  • charmling1 Nov 09, 2008
    Hi Scott,
    well lets see...I have three ports on the back of my pc for this...from left to right...pink (mike) green (speaker) and blue...(I don't know what that is). My device managers states that everything is working find. So no to flagged entries. I also found out that IDT Audio control panel is somehow involved...this is so annoying me right now.
    THanks for trying!
    Guru:
  • 558 Answers
Have you try with another Headset if you have?? May be the connector gone bad. Let me know in either case before vote solution.
Posted on Nov 08, 2008
  • Puneet Jain
    Puneet Jain Nov 08, 2008
    How many connector are present on your PC? Do you found any Flagged entry in Device manager?
    Let me know if you are comfortable with Remote session.
  • Puneet Jain
    Since if the sound works with plug in same connector, may be the newly purchased Headset not compatible or may be malfunctioning.. Try to run some other audio file or video file and try it with both (Headset and other audio device you have)
Mic not working properly : I have a iNTEX Headphone with a mic, the mic is not working at all. I've tried recording my voice(which did not work out),In control Panel the default Voice recording device is...
u need to check u r sound setting .plz click on sound icon in taskbar then click on sound property and recording there u can check u r mic if mic not working so srry dude u need to buy a new mic kkkkkkk
Oct 28, 2009 | Logitech Premium Headset
Headset Microphone doesn't work
Plugged in? Is it a stereo plug? does your computer allow speaker and mic on the same wire? Does the outlet say Mic or Headset of Both? Had it worked in the past.
Some computers have a place for a mic - some for headset - some might have both. On a desktop, I would expect to find separate connections. Laptop, Id have to look.
A 'stereo' plug will have a tip, ring and barrel connection.
A 'mono' plug will have a tip and barrel connection only.
A stereo plug would allow a mic and head phone connection ujsing a 'common' for the return.
A mono plug would allow either a mic or a headset, not both.
If you could peer into the jack inside your computer, you could tell if it privides for three wire (stereo) or two wire (mono) operation.
I hope this helps ... If I missed your question, please reask.
We are "paid" here by positive comments where we earn "bragging rights" If you are satisfied, please post positive comments
thanks
a
Oct 12, 2009 | Computers & Internet
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
Sound from one speaker with mic plugged in.
Hi I am Vortash it sounds to me that this is linked to the realtek program off shutting off the speakers when the earphones are attatched , it is confusing the Mic plug on one channel as a speaker plug .. check in the advanced section of your mixer settings that you have not got the box ticked that says treat all inputs the same .. and the other that says mute rear when front plugged in ? as does mine .. ( same system that was my problem yours may be diffrent ) if this fails uninstall your realtek drivers and uncheck the realtek devices in device manager unistall them and rebboot the computer installing new drivers .. hope this helps regards Vortash
Jul 21, 2009 | Philips HP-170 Headphones
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
HP Premium Sterio Headset ( mic also ) not working.
go to sound settings and then enable the mic by checking off the box.
Mar 28, 2009 | Video Game Consoles & Games
Logitech premium usb headset 350 help me pretty please
If when you talk into your mic you hear yourself from speakers...open your volume control(windows) and check the box to mute mic. Not for sure this is a fix to your problem but from what you wrote is similar to problem seen with voice chat software.
Feb 16, 2009 | Video Game Consoles & Games
Logitech headset
it is due to mic problem
1. mic cable may breaked
sol. check cable
2. other wise ur pc mic supporting software is not properly added
sol. if u r using windows xp, double click the volume icon ( located on ur desktop startmenu bar) click options, properties,
recording, and check the microphone then click ok button
check and select the microphone button and increase the volume and check it
3. check sound functions, some times ur software used in voice cancelation mode change mode.
Dec 31, 2007 | Logitech Precision PC Gaming Open Air...
Head set problem with vista
you will need to go into the sound manager in control panel and make sure that the external mic is enabled as the default use and ensure in the sound settings that the mic is not muted, this is normally done by right clicking the speaker icon in the taskbar and selecting options and see if the mic is muted or not in the properties
May 26, 2007 | Logitech Premium Stereo Consumer Headset
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
