Question about Kenmore 22062 Top Load Washer
Calypso washer 22066 locks up and beeps
Our Calypso washer starts beeping and the control panel gets locked up. It is displaying lights: Wool/Silk, Auto Temp Control, Cold/Cold, Minimum, and "6" in the minutes remaining space. Sometime I can clear the display, push the cycle I want and push start. It will work fine except it beeps all throughout the cycle. Other times, I can't get it off of the frozen display. It works only about 25% of the time. Any ideas what is wrong with it?
Model # 110.22066100
Serial # CL 1102898
Type 170
  • Anonymous Dec 11, 2008
    I had the same problem. My Calypso has had a lot of problems..will never buy again.
    I did sort of fix the problem and it's been working great so far. The key is to get out of the 'normal' cycle and never go back into it! After a game of constantly pushing buttons inbetween cycles and never knowing what combination was actually getting me 'unstuck', I figured out one day that everytime I ran a normal cycle, the machine messed up from that point on. Now, I only hit the 'whites' button and then change the water temperature accordingly, add an extra spin, soak, whatever I need. I have done this continually for several weeks and no longer get stuck in a cycle OR get the annoying beeps all night. So far, so good. I realize that I'm not getting the use that I paid for in this piece of ****, but at least I can do laundry. STAY AWAY FROM THE NORMAL CYCLE BUTTON!
    Lori Jeltema, Yorktown, VA
5 Suggested Answers
  • 3 Answers
SOURCE: Calypso 22066 top=load washer
You probably have hoses and sump pump plugged/jammed by not enough to the machine from operating, my machine leaked prior to cleaning out all the hoses and sump pump
Posted on Oct 07, 2008
SOURCE: Damaging clothes
Put garments in a laundry mesh bag or pillow case...silk will snag on even the smallest imperfections in the drum. Then do the extra gentle wash the other person suggested. Other wise always hand wash in very cool water and mild soap.NEVER use a bio, ever!
Posted on Oct 18, 2008
protek480
  • 1723 Answers
SOURCE: I have a kenmore elite
Start here, then let me know what you see:
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press RINSE
HOLD four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press RINSE HOLD two times.
Posted on Aug 24, 2009
jharvey572
  • 447 Answers
SOURCE: Kenmore elite calypso 22066 runs through cycle but
check the water inlet solinoid to see if its working
Posted on Jul 24, 2011
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Apr 25, 2015 | Refrigerators
How do you get the model 370lb to stopping beeping
Mar 30, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
How do I get my refrigerator to stop beeping
Sep 10, 2014 | Samsung RF4267HARS Stainless Steel French...
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Calypso washer display is freaking out.. It
change the panel. buttons are shorted wool button
Feb 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Dryer says locked
The Operating Instructions say this:
Control Lock
To avoid having someone accidentally start or stop
the washer, press OPTIONS and Select at the same
time and hold for about 10 seconds until the
(Control Lock) lights up. “LOC” will be displayed
alternately with the estimated cycle time. Turning
the Cycle Selector knob or pressing any button
will produce flashing indicator lights and/or beeping.
To unlock the controls, press and hold OPTIONS
and Select for about 10 seconds.
Oct 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Temperature control panel beeping
There are 3 models with this model #,so not sure if your has lock.
If it does and still changes,contact ge and tell them what is happening,maybe they will send you out a new control panel,if the warranty expired,depends.But it doesn't hurt to try.
This feature allows you to lock the controls
so the settings cannot be changed.
To lock the controls:
Set the controls to the desired settings.
Press and hold the lock pad for
3 seconds.
When the controls are locked, the indicator
light will come on and the control settings
will not be displayed.
To unlock the controls:
Press and hold the lock pad for 3 seconds.
After unlocking the controls, the settings
will be displayed, the lock indicator light
will go out and the settings can be changed.
Apr 14, 2009 | GE PTS22LBN Top Freezer Refrigerator
Beeping and Frozen, 44 min
If it is a Calypso, abandon it immediately... it is amazing you still have it. One of the worst designs, ever. Whirlpool Washing Machine Drain Pump 285990 No Longer Available
Apr 23, 2017 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22062 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
