Question about Roper RAB2121KW Top Load Washer
Roper rab2121kw top load washer
My machine fill's with water either hot or cold but after it fill's it humm's for a few sacond's then stop's. what can be the problae.
    President:
  • 878 Answers
By the sound of it, it sounds like you have somethng stuck in your pump stopping the motor. Start with this first. Remove the cabinet and the pump sits right in front, two clips and two clamps and it pulls right off. I will attach some photos to guide you. In the case that you need a new pump the part number is 3363394. Easy job...Catriver..post back
Posted on Oct 23, 2006
  • Ron Marek
    Ron Marek Oct 23, 2006
    pump with the cabinet off
WM2487HRM Hot water will not fill, soleniod good, single plug with three wires.
is the water off perhaps.Fact the solonoid hums sounds like it.
Oct 20, 2017 | Washing Machines
No water flowing into drum, water supply is fine, just humms
My Samsung washer was not filling with water after cleaning the debris filter. All I did to fix it was to dump a half gallon of water into the tumbler, then I ran the beginning of the rinse cycle and it worked. It seems like the pump needed to be primed.
Sep 16, 2010 | Samsung WF337AA Front Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Hi there my hotpoint washing machinewma 54 fills up without the machine being on
Hello. your fill valve is faulty and needs to be replaced.
here is how the fill valve is supposed to work:
The fill valve--which is about the size of a coffee cup--is sometimes also called a "water inlet valve." It controls the entry of hot and cold water into the machine. The valve has three major components:
  • A hot-water solenoid
  • A cold-water solenoid
  • A mixing valve body
The inlet valve has three hoses connected to it, for :
  • The hot water from the house
  • The cold water from the house
  • The water directed into the washing machine's inner tub (either hot or cold, or both) to fill it with water
When electricity flows to one or both solenoids, water flows through the valve into the washing machine's inner tub. When the electricity stops, the water also stops.
Aug 21, 2009 | Washing Machines
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Roper RAB2121KW Top Load Washer Logo
82 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
