Question about Frigidaire GLTF1670A Front Load Washer
Will fill with water but during rinse and spins it won't drain.
No matter what wash the machine is performing, it will not drain the water. The cycles will complete on the dial and agitation will occur but the pump simply makes a humming sound and will not drain. In addition it appears as final spins do not actually spin which I assume is because there is still water in the drum. Machine type is actually FWT449GFS1. Fridgidare Gallery
  • 1 more comment
  • Geobianco Apr 22, 2009
    I actually have 2 of these machines and both run thru the cycle but stop spinning part way thru the spin cycle leaving soggy clothes
    One machine spins for longer than the other but both don't do too good of a job
    model FW 449GFS1
  • Anonymous Mar 26, 2014
    The control panel lights up properly and the locking mechanism works but it won't actually start to run water. It has water at bottom of drum as if it didn't full complete last wash cycle
  • Anonymous Mar 29, 2014
    The dial does not progress and there is a buzzing sound. I can turn it to final spin and it goes.
I fixed it on my own. By taking off the suction hose and spinning the fan inside it apparently dislodged something and is working now. Hopefully the problem won't come back, I was unable to find the foreign object.
Posted on Oct 23, 2006
Similar problem, had I. In my case, the fins on the impeller in the drain pump had worn down to the point that it no longer pumped water. It had obviously had trouble for a long time, but finally got to the point where it couldn't even pump below the drum. Probably it had pumped too much sand, kitty litter, coins, etc. over the years. I replaced the pump, and heard a sound I realized I hadn't heard for several years: the pump sucking air when draining.
I think the clothes are going to get cleaner now without all of that residual dirty water.
I did collect a good pile of coins out of the trap, but not enough to pay for the pump, unfortunately. Kind of a bummer to pay $75+shipping for a replacement pump, when all that was wrong was an impeller that's probably worth $4.
Posted on May 21, 2009
My machine wouldn't spin propely and it turned out that the problem was that the water was not draining fast enough. I found several coins in the drain boot and some nickels clogging the artery right before the pump. See http://www.applianceaid.com/frigidaire_frontload_washer3.html for a description as to how to get at the pump. To reassemble, I used a vice grip to hold the clamps open to make it easy to get the hoses on the tubes.
Posted on Apr 08, 2007
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Frigidaire GLTF1670A Front Load Washer Logo
378 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
