Problem with Daewoo DTQ-13P2FC 13" TV
A couple years ago I made a parental control password and since I never really touched the parental control password. I have forgotten what it is and I need to know how to reset it. Please help!!!
84,751 people viewed this problem
This solution has been voted best by the Fixya Commnunity
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
ConfusedEasy unplug wat?
Nov 30, 2010
alamgir kabir
3308 also worked for parental control on daewoo DX7840 DVD+VCR
thankoo Sir ;) but still i cudnt make tht to play DVD :) i can hear songs / even VCD but no DVD
If u can help :) it will be great for me :)
Sep 17, 2011
alamgir kabir
another one just i found hehe :) for tht model DX7840 DVD+VCR to free rigion code do please
1. open tray
2.press 0 5 2 0
3. UP >DOWN > LEFT > RIGHT
4. if it show a little time region lock then please do again 1. 2. 3.and this time it will show region free
try it please
Sep 17, 2011
alamgir kabir another one just i found hehe :) for tht model DX7840 DVD+VCR to free rigion code do please * open tray>press 0 5 2 0 > UP >DOWN > LEFT > RIGHT and if it show a little time region lock then please do again * .> > > .and this time it will show region free try it please
Sep 17, 2011
As per the owners manual - be sure TV is OFF - hold the volume down button on the front of the TV AND the clear button on the remote - the TV will automatically turn back on - set new password when you go into parental controls again.
alliemsucc what's the clear button? i have a direct tv remote..
Sep 27, 2010
Enter the master password 4357 to reset then create a new one. Found this on the web and worked for me.
From Daewoo customer Service:
"You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work."
redeyerudy01 2211 worked on my 4 year old 27" inch .
Jul 03, 2011
If you forget your password, press and hold TV on the remote and the MENU
button on the television simultaneously for 3 seconds. Parental controls will
then unlock and you can re-enter a password via Lock Parental Controls.
Heiress L Thank you so much that worked.yes I have been trying to find thos solution for months.
Feb 26, 2012
The only way to set the TV back to a state where it has no password is to find an internal battery.
If this can be located and removed for say, a day or two, or the connections shorted for a few seconds, where the battery was, then the battery replaced.
The memory parts should now be back to normal so that the TV can be reprogrammed with TV stations.
i am not an expert however I have been having trouble with my Philips TV for months now. Factory set access 0711 is the default for alot of philips TV's. Try keying in this number to get to access code to store new one. I hope your problem is'nt like mine only 8 months old and it keeps shuting off because it loses it's memory and keeps thinking the channels are blocked. It therefore shuts off immediately when it is turned on. Good Luck!
PS. The only expert advice I could give is don't buy Philips brand ever again!
4357 is the master code i dont know the rest
coka cola be quiet
Dec 15, 2009
BigGame_Hunt This worked for my Sony KDF 50E2000
Sep 14, 2010
I googled the manual for the polaroid TTM-2401 TV and it says that the master code for that tv is 410000 I tried it and it worked!!
I have a TCL lcd tv, we dont know the password, is it possible to reset it somehow. Thanks, bejss
dmwwjd Have just found out that 6666 is the master code, works perfect
Nov 06, 2010
My GE manual states to override a forgotten password, use remote to access the main menu, then select parental control, when the enter password screen appears use the tv's front control panel press and hold at the same time the ch+ and vol+ for 8 seconds. You will receive an on screen message the parental control have unlocked....... I must admit, this did not work for me. Still open to other ideas.
martin smith Try this; with the TV on, hold the volume down on the remote and at the same time press & hold the menu button on the TV for 8 seconds. Then check paternal control, it should be unlocked......This worked for me.
Feb 06, 2007
Hope Im Not Late You Can Also Hold Channel - And Volume + At The Same Time On The Tv While It Is On And It Will Be Reset To 0000
Yo im a kid who figured out this prob trying to hack parental control lol you can thank my generationXD okay if u still have ur email click forgot password it'll send a temporary pass to u so u can reset it if not just make a new account on ur comp it wont give u a new parental control password but the new account has absolutely no restrictions since the limits arent set on it XD UR WELCOME azn4lyfe
Look for user manuals at http://www.user-manual-search.com
I have a misubichi tv but i for got passwork for the parent lock
I have a proview tv PA-37JK1A and the parental control code has been changed and I don,t know the code how can I remove the parental control code. Is there a master code or something for this tv?
OK I HAVE A haier tv and idk but NON OF THIS STUFF WORKS i have tried it all but..... say """"BLOCKED DUE TO V-GUIDE"""""
and like a tv-pg -- tv-pg 14 on it on rly every channel
4357 the master code then you type new password...its working i try it before...
FOLLOW SOLUTION #2 from chris5563 for RCA 19" TV mod# F19430 built y2k!!!!! Can't tell you how many other procedures I tried with NO success; I've had this stupid thing for 3 years. Then I found suggestion from chris5563: from remote control press MENU, toggle to 'Parental Control', press >+, at enter password - type in 2211 - BAM!!! UNLOCKED!!! AWESOME!!! Now I can watch MANswers on SpikeTV!!! Thanks chris5563, you the man!!!
Chris5563, you are awesome!! Unplugging and code 2211 worked on my Daewoo tv...even with a $4.00 replacement universal remote!! Thanks!
manavsood hello guys i have a insignia tv and pg-tv channels dont work plzz help anyone plzzzz
Sep 26, 2010
Problem - Legend Television blue screen with red lock in upper left hand corner.
Solution - Press and hold display button on the remote for 3sec, then the problem will be solved.
Iforgot my password for an older rca tv
I have 27" Prima TV. It is locked by accident. Please anyone have ideal to unlock parent control on remote?
Turn tv off, then press and hold 'volume' on tv and 'clear' on remote for at least 5 seconds.
indstiks Worked great. Couldn't find info anywhere. Thank you very much!!
Jan 25, 2011
Granddaughter has Forgotten Windows Vista Premium password.
I forgot my password
Call ur cable operator. They will tell u a new password or they will come and rest it.
Factory settings!! Problem solved. Am I right?? I'm not wrong!!!
Kabboooom Your not wrong!!!! (Sony Bravia LCD)
Aug 31, 2011
I have a disney tinkerbell tv that was gifted to me. it was preiviously owned, but barely used. it has a parental lock on and I dont know how to get it unlocked. the person cantremember the password either.
ok ok .... I set the parental code on this tv and used it for several years. The tv was put away and now I want to use...
A couple years ago I made a parental control password and since I never really touched the parental control password. I...
me and my husdband have direct T.V. and there is somehow a parental lock on our T.V. but me nor my husband put it on...
john tserionis I have a philips t.v. and i forgot my password.Can you help me ? my e-mail is jtserionis@hotmail.com
Dec 28, 2011
john tserionis I DONT REMEMBER THE PASSCODE TO UNLOCK MY TV CHANNELS. I HAVE A PHILIPS 37PF9731D 37".ANY IDEAS?? IS THERE ANY RESET BUTTON??PLEASE I NEED YOUR HELP!!!
Dec 30, 2011
devildaddy71 Chris5563, You are the BOMB!! Unplugging and code 2211 worked on the Daewoo. Even with a replacement universal $4.00 remote.
Feb 28, 2010
binyambeyene my sister changed the mastercode could you help me.
Dec 19, 2009
raymonddixon I have a poineer flatscreen tv large one and i have just moved house i plugged it in and a passcode boxes keep appearing after i set time and dates and i cant find my user manual or remember codes please can somone help me as my kids are really upset with me
Thanks for any support
Aug 20, 2009
sniper_tapaa my daewoo tv showing blue screen with lock symbol on screen only sound is there but no other function tell me wht to do
May 02, 2009
Guest forgot parental control password and need to change it for rca tv
Apr 29, 2009
Guest i want to have ***
Apr 20, 2009
Guest I CANT REMEMBER MY PASSWORD TO DISBLOCK THE PARENTAL CONTROL.HELP!!!!!!!!!!!!!!
Apr 17, 2009
Guest I have an LCD Prima tv. the code on he back says LV-2628P ans i need to know ho to fix the parental code. i set it and nowforget it. PLEASE HELP please email answers to alwaysorange_94@hotmail.com
Apr 12, 2009
Apr 12, 2009
Guest i forget my password so please could some want help me i have parenrtal control problem if you found out anubody please let me know email @ localbiyow@gmail.com
thanks that it will helpful for me
Apr 02, 2009
vladimirokay i forgot my parental password on my sony t.v. sent me how to reset it my gmail is vladimirokay@gmail.com
Mar 30, 2009
carolyn31960 i forgot my parental control pass and i need a new one sent to emal adress carolyn31960@yahoo.com
Mar 23, 2009
nikki08642 i forgot my password to perenel control how do i find it out without changing the password that i have now
Mar 22, 2009
Guest I am a parent aged 37from Kenya. I have never had a parental control password yet whenever I try to access some of my favourite pictures, access is denied and am asked for a password to fix the problem. What should I do?
Mar 07, 2009
Lucy56 I have forgotten the parental control password for a dynex lcd 19"tv. I have tried the code in the manual and also the suggested 0000 from the customer service operatot. It is now locked for 180 minutes after 3 tries. Help!!!
Mar 03, 2009
Guest i forgo my parental control password and now i can't go on any sites
Feb 27, 2009
Guest help i have put parental control can some1 tell me how to find out what the password is
Feb 07, 2009
Guest i have set it so you can't go on after 9.00 pm and i have to go on my daughter's user. help!
Feb 04, 2009
Guest forgot password
Feb 03, 2009
Guest my techer put a parent code on my computer but i cant change anything
Jan 02, 2009
01Patty Someone put a password for the parental control and now they cant remember it.
Dec 29, 2008
nckbroderick unblock code
Dec 22, 2008
amberhenders umm. my daughter set a parental control passcode on the tv and we have forgotten the passcode how can we unlock it??
Oct 14, 2008
vicskitty444 I have had the tv for years and never put a parental code on it. I moved and then one night while watching family guy, it blocked it from the tv. Now it blocks almost everything I watch unless it is cartoons. It tells me to enter a code but I dont know the code. I dont have the remote. All i have is a direct tv remote.
Oct 13, 2008
Guest i forgot my password
Sep 04, 2008
kimnmorrow i put this parental control on my computer but i forgot the password and i dont know how to get it back and now many stuffs on my comp have been block unless with the password.
Aug 24, 2008
Guest i forgot th p assword for the parental control in the pc
how can i unlocked it?
Aug 17, 2008
Guest i need to turn off this parental password completely. but i forgot this unblock passcode. any suggestions?
Aug 09, 2008
Guest i have forgotten my password
Jul 03, 2008
Guest Daewoo DTQ-13P2FC 13" TV
May 31, 2008
Guest i buy my tv and i'm not able to watch some movie even simple movie i would like the restart it or take it off thank you
May 30, 2008
wendystoys Have a panasonic model ct-20g6 television need to reset parental lock code. thank you
May 26, 2008
Chocorron I Forgot my partental control password. Could you help me. My TV is a RCA and the model is F36649, serie 130521555 and the chasis CTC 203CA5
May 07, 2008
myrkaal A couple years ago I made a parental control password and since I never really touched the parental control password. I have forgotten what it is and I need to know how to reset it. Please help!!!
Apr 24, 2008
Guest I've forgotten my Parental Control password and need to reset it. How do I do that.
Apr 21, 2008
NLsoldier reset parental control
Mar 26, 2008
Guest I have a Daewoo DTQ 27S3FCN 27"in i have not used the tv in years, I have forgotten the password. Is there a way to reset the password?
Feb 29, 2008
Guest i forgot my parental controls password and my email for it
Feb 28, 2008
anabananna i cant
Feb 27, 2008
Guest how do you reset forgotten parental control password
Feb 21, 2008
kimi_raja i forgot the parental control can you please tell me
Feb 14, 2008
autozoner i set a parental control password to stop the access of any and all porn web sites and unfortunately i forgot it and the one i did use does not prevent all aforementioned web sites. can you help
Dec 30, 2007
Guest I think my problem is a parental control but am not sure. Something was inadvertantly pressed on the remote and now there is a black box blocing most of the screen. How do I get the full picture back?
Dec 23, 2007
Guest I HAD GOTTEN AN RCA FLATSCREEN 27 IN CH TV AND IT HAS THE FRONT PARENTAL LOCK ON AND I CANT ACCESS MANY CHANNELS. I DONT HAVE THE ORIGINAL REMOTE I HAVE A ONE FOR ALL. HOW DO I GET THE FRONT PARENTAL LOCK OFF. PLEASE HELP
Dec 14, 2007
calentadora I forgot the password my tv is sharp.
Dec 13, 2007
Guest I forgot the code I want to reset againg my tv is Sharp
Dec 13, 2007
Guest trutech tv i do not know how to unlock parental lock; it was already on it please help
Dec 10, 2007
jazb I moved into a house that had a T.V. DVD player connected in it, and I called the landlords, and they don't remember the password. Help, I'm sick of Disney Movies......Jessica
Dec 09, 2007
tootie000 I have a RCA27R410T that I bought from a pawn shop. the parental control is on and I don't know the password.
Nov 18, 2007
jess32 i was given a tv daewoo dtq-19v1fc. it has parental control on it and no one knows what the password is to unlock this feature. i am trying to figure out how to access all channels. i have tried all solutions offered except to disconnect internal battery because i wouldn't even know where to begin. is there another way?
Nov 02, 2007
Guest i was given tv daewoo dtq-19v1fc. it has parental control lock on it and i need to figure out how to reset this so that i can access all channels. please help
Nov 02, 2007
