Doesnt stop pouring water
When I start any cicle my washing machine starts pouring water as it's supposed to do but it never stops pouring until I turn it off
  • pacokiko Nov 08, 2008
    when I start any cicle my washing machine starts pouring water as it's supposed to do but it never stops pouring until I turn it off. (my washing machine is series 70)
    New Friend:
Then no prob with pressure switch as other function works. Inlet valve works fine.maybe pcb board problem because once the water reach to the level, pressure switch will send signal to pcb board to start washing and stop the water intake. Here iis power supply to water inlet valve never been stopped.
Posted on Nov 12, 2015
  • 62 Answers
It is suppose to turn off, bad fill valve.
Posted on Nov 08, 2008
My Samsung washing machine wont stop with water filling
First clean the detergent drawer and button trap, then make sure the siphon cap {it might say "MAX" on it) is installed properly. Make sure water pressure is not too high.
Apr 18, 2016 | Samsung Washing Machines
Washing machines problems
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
Dec 09, 2017 | Washing Machines
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
The washer just stopped pouring water. Only faint humming sound.
Cool!
How 'bout a FixYa for the effort, and let me know if you need anything else.
Feb 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
THE WM DOESNT STOP FILLING UP WATER
It sounds like your water level switch is bad and needs to be replaced. The inlet valve opens and starts filling, and timer operation is suspended until the water level switch operates.
Jan 10, 2009 | Kenmore 24902 Top Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Flashing lights
You have a heat problem, using a test meter check the heater element, then check the thermostat if niether of these you have a PCB fault Regards Engineer
Mar 15, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
