Question about NetGear Super G Wireless Router
Netgear router i cannot configer it to my xbox360 and cannot find windows connect now to help me
    Guru:
  • 523 Answers
Dear Friend,
                 Kindly the follow the below steps and revert back
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Enabling DMZ:
1. On the left side of the setup page, click on the WAN Setup under Advanced tab.
Regards,
Aysaam
Posted on May 05, 2009
    Problem Solver:
  • 12 Answers
Have you followed these steps?
Posted on Nov 08, 2008
Xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Sep 19, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
Can't access configuration for Wgr614 v5 Netgear Wireless router
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Dec 22, 2008 | NetGear WGR614 Wireless Router
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
CONFIG. NETGEAR ROUTER
did you install the modem software and the router software? you may also want to use the network wizard to see what it tells you. are you wired or wireless at the pc? if a laptop, did you install the wireless connection (either a usb or internal)?
here is how to set up the network. netgear is the same way.
http://lifehacker.com/software/wifi/geek-to-live-set-up-a-home-wireless-network-162754.php
Oct 20, 2008 | NetGear WGT624 Wireless Router
CONNECTION TO ROUTER WGR614 V6
Do u have any wireless security set on ur router ?
do a IP config/all in MS Dos window. then, note down the default gateways IP address. Then, open a browser and put the IP in the address bar. this will open ur Router's Config page.
Go under security to see if u have WEP or WAP turned on.
Apr 17, 2008 | NetGear WGR614 Wireless Router
Xbox360 connection problem
The generic connection and configuration document
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
This is a good description of possible router options.
http://www.ianarchbold.com/xboxlive/index.html
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 22, 2007 | NetGear WGR614 Wireless Router
Xbox360 Live
you will need to call tech support for linksys on this one xbox might have diff setup that may need configed
Sep 23, 2007 | Linksys Wireless-N WRT150N Router
NetGear Super G Wireless Router Logo
165 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
