Question about Dell E153FP 15" LCD Monitor
E153FP Monitor screen goes black light is green
My dell monitor screen keeps going black after being on for a few seconds. If I turn it on and off the picture is there for about 5 seconds then the monitor goes black. It is definitly a monitor issue, I've put a different monitor on the computer and its working fine, also tested the flat panel on my laptop and had the same issues. I looked for a reset button cant find one anywhere or how you even get the back off of the monitor.It is now out of warrenty and I am not sure how to go about fixing this problem.
    Problem Solver:
  • 5 Answers
The capacitors are probably bad. It is a common problem and easily fixed by taking it apart and replacing the capacitors. Try to find Rubycon Capacitors because they very rarely go bad. Do a search on google for bad caps. I have fixed about 30 monitors this way. Dell is a company well known for bad capacitors. It may not be your problem but replacing the capacitors should cost less than $10 if you do it yourself. www.photphot.com
Posted on May 15, 2007
I agree. The capacitors have popped. I found a local TV repair shop and the guy put new capacitors on the board for me for $5, so it's an easy fix. The monitor is difficult to get apart, but if you'll look carefully you can see small slots in the plastic, mine were on the bottom side, then insert a very tiny flat screwdriver carefully seperating the cover, using a slightly larger screwdriver in the gap, twist gently until the case pops open. Remember to take all the screws out of the exterior, and not to push the screwdriver in too far and scratch the screen. Good Luck.
Posted on Jul 30, 2007
Dell Inspirion 546 screen keeps going black
It sounds like a hardware fault, does it happen when the laptop is cold or does it start to go faulty after its been on a while, if it goes faulty after its been on a while, its more than likely that the fan cooler is all blocked up with dust, and will need to be cleaned. Hope this helps.
Nov 25, 2016 | Dell Computers & Internet
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Dell 1908FP monitor goes black after a few seconds
As I scrolled through your solution a smile began to creep over my face starting with "this can be lethal." Each picture frame I scrolled past began to formulate my strategy. Your instructions could not have been more clear and precise, detailed, easily understood. When I reached the last picture my plan was put into action. Off to buy a new monitor lol, you must have the patience of Job. Thanks.
Dec 19, 2012 | Dell UltraSharp 1908FP Monitor
Screen goes black for a second or two every few minutes
This indicates the inverter transformer is going or a capacitor issue.
May 08, 2012 | HP LP3065 Monitor
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
No picture on monitor (monitor turns itself off)
You will need to take it for repairs.
Sorry
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Dell E773C 17" CRT Monitor
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
The screen went black after few seconds.
Hello Chris,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the strip on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | Dell E193FP 19" LCD Monitor
My monitor keeps going to a black screen a coulpe of seconds after being turned on
Video (picture) must be constantly entering a monitor for a monitor to continue to display a picture after it self tests (goes on for a second or, two) Your monitor is fine; check it using another known good computer.
May 20, 2009 | Vision Computers & Internet
Dell E153FP 15" LCD Monitor Logo
1,047 people viewed this question
Clive
Clive
Alun Cox
