Question about RCA RT2250 System
I can only get sound when I hook up speakers to the 6 channel option
When I first got the receiver, it flashed mute all the time and could not get any sound. I am now only able to get sound if I hook up things through the 6 channels option. I can not utilized the surround sound options or hook up anything to the jacks at the back for CD, DVD, TV etc.
SOURCE: strange audio problems
called a tve repair man tha is a buddy of minr hr had me unplug the tv to reset the ic ship and it worked !!! thanx and good luck
Posted on Sep 05, 2007
  • 236 Answers
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Posted on Sep 09, 2007
SOURCE: no sound
Maybe the audio amplifiers ICs are damaged.
Posted on May 21, 2008
  • 34 Answers
SOURCE: direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Posted on Nov 21, 2008
mattballew
  • 89 Answers
SOURCE: cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Posted on Nov 25, 2008
Trying to hook up surround sound receiver just like the manual shows but I cant get any sound from the tv but I can get music from the tuner part any suggestions?
Have you enabled the external speaker option on your TV and the set isn't on Mute? Check that you have the surround system's receiver set to the correct input. Next, check the audio level. On some sources for the TV, I need the volume at 65. Other sources sound fine with the receiver at 45. Check that the audio matches that being sent by the TV. On my TV, I needed to go to the Menu > Audio Settings to find the option for turning on the external speakers. Then I had to set the speaker system to Multi-Channel for our specific setup. (There were several options, including Dolby. For my specific setup, these other options didn't give the correct sound.) Finally try a different audio cable between the TV and the receiver.
I hope this helps. Please add a comment with the make and model number of your TV for additional advice. Adding the type of connection (digital audio (optical/coaxial), HDMI, RCA) will help me suggest potential problem areas.
Apr 21, 2015 | Audio Players & Recorders
Power light is on but no sound
verify circuit breaker or fuses. check mute toggle if equipped with mute.
Nov 27, 2013 | Pioneer VSX-D510 Receiver
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Apr 07, 2013 | JVC RX-9010V Receiver
Corner of the radio is flashing ATT
ATT is like a mute option, hit mute or ATT button to return to normal operation.
May 15, 2012 | Kenwood KDCX895
I accidentially hit a button on the remote on my Yamaha receiver, now there is no sound coming out of the speakers on the surround sound
Examine the indicators on the panel carefully. I'm sure a clue is there. Maybe a wrong source, mute, speakers off, tape or 6-channel input activated?
Select FM, tune a station, leave the volume set midway and use THAT as a troubleshooting tool. Eventually, you'll find the switch or button.
Feb 18, 2011 | Yamaha HTR-5590 Receiver
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
I have an old Sansui 400 receiver. I get no sound from the left channel--both A and B speaker options. The speaker and wires are OK, because they work when hooked to the right channel contacts.
The problem seems to be the left transistor part of the unit. Try this:change A versus B speakers, asuming speaker A was working properly. If still speaker A, now connected to left output does not work, you will probably have transistor malfunction on the left channel of the receiver. Any electronic store will substitute the left transistors.
Good Luck.
Flavio/BRAZIL
Jul 23, 2010 | Sansui Audio Players & Recorders
RCA RT2250 System Logo
27 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
