Question about Garden
CUB CADET BROKEN SHAFT
I HAVE A 4 STROKE CUB CADET WEED EATER WITH INTERCHANGEABLE SHAFTS (SAW, TRIMMER), WHICH IS LESS THAN A YEAR OLD. THE SHAFT THAT IS CONNECTED TO THE ENGINE LOOKS LIKE IT IS STRIPPED. INSTEAD OF BEING SQUARED, IT IS NOW ROUNDED AND WIIL NOT OPERATE MY ATTACHMENTS (IT JUST SPINS). IS THERE A FIX TO THIS PROBLEM OR DO I NEED TO JUST BUY A NEW ONE? AND IF I NEED TO BUY A NEW ONE, WHICH ONE WITH INTERCHANGEABLE ATTCHEMENTS? PLEASE, ADVICE IS NEEDED. THANKS IN ADVANCE.
 GARY
  • 1 more comment
  • Anonymous May 06, 2009
    I have the exact same problem! I took the first cub cadet back and had it exchanged for the same mdoel, but it did the same thing. I wasn't even working it hard, I just used the hedge trimmer and it stripped in less than an hour of usage! I exchanged it for a new one and hooked up the lawn edger which also quit working now. I looked at the shaft of the accessories and they have been rounded off and the shaft inside is rounded off!
  • jtmfoley May 25, 2009
    i have the same problem. my cub cadet 4075 edger is useless now that the shaft and gears in the lower end are both stripped. think we all need to go to a stihl or echo !!!!!
  • mg914
    mg914 Mar 19, 2012
    The zinc alloy accessory drive socket on the upper flex shaft of my CC2025 stripped in one year of light use. I made a new steel one, and it lasted about four years. I now have an Echo, but need to re-do the CC fix bc the accessory shafts are different diameters. All this would be unneccesary if the drive socket were made of tougher material.
  • 17 Answers
If you have a invoice of your purchase, Check your owners manual it should have a contact for your nearest warranty agent. Give them a call, make shore you have your D.O.P and model number.Hope that helps
Posted on Jan 12, 2009
Model BC 490 weed eater blows oil from air filter. Could the egr valve be bad ?
3 year warranty on that machine.
4 stroke engine. sounds like too much crank pressure to me. Not sure if it has an EGR but you are on the right track
Mar 19, 2016 | Cub Cadet Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weedeater and Homelite shafts interchangeable?
    Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
    May 18, 2014 | Homelite Garden
    What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
    DO NOT USE MOTOR OIL!!!
    There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
    Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
    If this is really helpful, please rate.
    Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    I need a twist n Edge weedeater manual to find out how to put more string on the spindle
    You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
    Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
    Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
    New wife has cc4125. How do you replace trim wire
    Hello South Texas from former Mesquite resident!
    If this does you any good, get your Model and Serial no. and can go to this web address and download the owners manual:
    http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=30000
    Sep 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
    Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
    rotate attatchment head slightly while inserting driveshaft
    Jul 30, 2009 | Garden
    Garden Logo
    666 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
