Kenmore 80 series agitator problem
Hi have a Kenmore 80 series washer. When the washer engages the agitator, there's a loud "clank" noise. It also makes this noise when it engages into spin mode. The top agitator seems to be working correctly, but the bottom one is barely moving thus causing clothes to wrap around and stress or cause the washer to stop.
  • 62 Answers
Time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Posted on Nov 08, 2008
My top loading Kenmore Series 80 top loading washing will not run. When I noticed the motor would not engage agitation, I checked the circuit breaker and found that it had switched off. Turned breaker...
I would use a voltmeter and test the power to the motor. If there is power, then motor is faulty. If motor spins but not agitator then ****** could be bad. If no power to the motor, then a fuse or main circuit capacitor may be bad but testing with a manual and multi-tester meter will be needed to test for the failed componenent
Jun 09, 2012 | Kenmore series 80 Washer Motor 3363737-
Series 80 won't agitate or spin will pump out water
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you
Aug 15, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore 80 Series washer won't agitate or spin. Makes noise.
sounds very much like the bushes have worn out on the motor,they are easy to replace take down model number to your nearest electrical shop and they will supply them for about £10.00
Jun 07, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Mar 09, 2009 | Kenmore Washing Machines
Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Sep 02, 2008 | Kenmore 24032\24036 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 series not agitating
Most likely you have a bad motor coupler. If you open the console and remove the two brass clips, this will let the front, sides and top all come off as you tilt it forward. At the botom center, you will find two metal clips holding the pump on. Remove. You will find 2 screws holding similar clips holding the motor on. Removed. On the back of the motor, is your coupler. Replace. Then re-assemble.
Jun 08, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
602 people viewed this question
Top Washing Machines Experts
