Question about Lenovo 3000 V100 Notebook
My lap top stopped workn suddenly.
When i turn the power on my laptop all i get is the battery light and the circle with the z in it. No start up screen nothing just a black screen.. Pleasa help.
Umbro watch instructions
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu:Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Jul 15, 2013 | Watches
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
How to repair my satellite lap top computer, which became suddenly black? and I re-started lap top and nothing happened
It would be impossible to diagnose your problem without more information.
You may need to take it to a repair shop.
Is your battery faulty?
Are there any lights on the laptop when yopu plug it in?
Have you checked the fuse in the power adapter?
Oct 14, 2010 | Computers & Internet
My toshiba laptop suddenly went into hibernation. I can't start it. What should I do?
mcdevito75 here, You can try to presss the shift key, also try to put your lap top on, with either AC wall power or battery. If this doesn"t work bring the lap top to a local Radio Shack, or Staples for help.
Jul 16, 2010 | Toshiba Satellite A215-S4697 Notebook PC
My lap top wont turn on i have a blankj screen the
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
thanx
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
Can't figure out how to deactivate the alarm on Umbro U564B watch
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Mar 03, 2009 | Bulova Watch
My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Jan 13, 2009 | HP Compaq Presario C500t Notebook
Lenovo 3000 V100 Notebook Logo
101 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
