I am trying to set up my computer to accept a wireless router but can't find where to turn on the wireless part in the computer.
  • Jannette Amandy May 11, 2010
    Is the computer you're referring to a laptop or a desktop?
    If it is a laptop, what is the model of it? If it is a desktop, what is the model of the wireless adapter you have installed to it?
    Scholar:
  • 112 Answers
If you are running vista, there should be a drop down menu that should allow you to turn it on or off. If not, go into internet settings. You should find a link to set up a connection there. If it doesn't run a diagnostic.
Posted on Nov 08, 2008
My router won't accept password that is on printout from when setup
Check the wireless settings of your router. Connect the computer to the router and open the setup page of the router. The wireless settings might be changed. Follow this link to find wireless network key
Nov 28, 2011 | Linksys Wireless-G WRT54G Router
Not accepting my login and password
Try restarting your computer. If this doesn't work try using the reset button on your router and set up your router again by connecting your router to your computer using an ethernet cable.
Mar 08, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Will not accept my security key
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Mar 18, 2010 | Linksys Wireless-G Broadband Router
Cant get computer to take security key number
what is the Operating system on the laptop ?
Sometimes on Windows 7 it will not accept the network key?
You will need rto change the security type to WPA
Change the wireless channel to 6.
try to change the SSID also.
then try to connect to the new network and see if that works.
You will need to open the set up page of the router.
click here for more info about routers and network
Jan 30, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Cant sign in to wireless password not accepted
Try to connect your computer with an ethernet cable with the router
Open the router interface using the default gateway that your computer is receiving
Under Wireless, select security and check the security mode and check the compatibility with your operating system.
Remove all preferred wireless networks from computer
If the compatibility is appropriate, and if security key is exact(case sensitive), this is sure to work
Jan 17, 2010 | Linksys WRT54G2 Wireless Router
Purchased a Belkin (N150) router this morning along with a new laptop. Problem - I can't get the laptop to accept the router. Don Hood
Is there any other computer connected to the network and able to go online.
If yes then check the wireless settings of the router.
If the laptop is the only 1 computer then you will need to connect the laptop to the router and open the router set up page and check the wireless settings.
Click Here for step by steps solution about router set up and how to connect to the network
Nov 28, 2009 | Belkin Computers & Internet
I am having WP54G wireless access point which is not showing sight survey signal. What i have to do anything software update is their.
On a computer that is plugged into the router,Open internet explorer and type 192.168.1.1 when the login box opens Type Admin in user and Admin in password,When router page open,Click wire tab and turn on wireless radio,It will say the router is now accepting connections,With the computer you are trying to get wireless on,Search for wireless signal,When it find the signal click connect,Go back to the router page and Click Save.You can also set up your security while in the router page but everything you put in must be the same that you later use on the wireless computer to connect. For example if you set the security to WEP and the password to 12345,when you try to connect it will ask for the WEP key and you will need to enter the 12345
Please take time to rate this fixya.
May 12, 2009 | Computers & Internet
I tried to secure my router but had trouble doing so, I cannot connect to the internet now
i assume that you have tried to secure your router using a wireless computer. if so, there's a possibilty that you have sucred your router successfully and you need to connect you computer again to the wireless signal using your password. if you can't remember your wireless password or if the password you are typing is not being accepted, you need to hardwire a computer to the router to double check the wireless settings that were enabled on the router. once you have verified all your wireless settings, connect the computer wirelessly and enter the correct wireless password/network key and check if you'll get internet connection again
hope this'll help you but if not just indicate the exact brand and model of your router and your wireless adapter.
ciao!
Aug 22, 2008 | Belkin (F5D7230-4) Router (587009)
Router to computer issues WRT54GS
Ensure that any firewall you may have is turned off, then try it again.
Oct 26, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
