Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kemmore refridge The freezer works perfectly. The area where you keep milk, ketchup, jelly, etc is not cooling. Any ideas what the problem is.
  • 120 Answers
IS THERE AIR FLOW INTO REFRIGERATOR PUT YOUR HAND BY THE DAMPER AND FEEL FOR COLD AIR IF NO AIR IS THE MOTOR FAN INSIDE FREEZER WORKING AT ALL IF NOT REPL IT THATS WHAT SEND AIR TO THE TOP PART IF IS RUNNING THE IT MIGHT BE A DEFROST PROBLEM DSICONNECT FOR 2 DAYS IF WORK OK CALL A TECH TO FIND WHAT PART IS FAILING ON THE DEFROST SYSTEM
Posted on Nov 10, 2008
Aeg arctis freezer
Check that the cooling pipes at the back of the freezer are not clogged with dust etc. and that there is sufficient space for air to circulate around them. If they are ok check that the freezer door seals are all intact and seal the freezer cabinet completely when the door is closed. Any gaps here will cause the compressor to over work in an attempt to keep the temperature low. If none of these suggestions then it could be a slow leak of the refridgent gas. A clue that this is the case is the freezer being a lot cooler at the top than the bottom of the cabinet.
Jan 06, 2014 | Freezers
Frigidaire refrigerator - Model #FRT21BHscW2 manfuactured in 2004 has stopped cooling - freezer unit works - icemaker works - fan is running and compressor is warm - unit is clear of dust and particles. ...
Hello
There is a plastic duct work leading from the freezer to the refridge.Check that there is nothing blocking this ductwork.Also check fan in freezer for operation.
Have a look a refridge door seal also make sure it has no cracks or is not coming off.
Jun 13, 2011 | Frigidaire Refrigerators
My refridge is not cooling but the freezer works perfect
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 05, 2010 | Amana ABB1927DE Bottom Freezer...
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Upper freezer is working but the temperature in the fridge part is approx. 65 degrees -- not cold.
This is a malfunction of the control board. The control board is telling the refridge side that it is plenty cold - so it doesn't divert the cold air needed to keep the refridge side cool enough. Check to see the the coils in the freezer are frozen - if they are, unplug the unit and defrost with a hair dryer. Dry up the water and turn it back on - that should solve your problem.
Aug 22, 2009 | Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Frigidaire side by side refridge
pull the kick plate off under the doors. if you look in behind the kick plate youll see alot of dust build up. this area needs to be cleaned once a year to keep air flowing properly over the condenser coils. if the dust build up is minimal then remove back panel of refrigerator and make sure the fan is running behind the refrigerator. if not, or if running real slow replace the fan motor. the heat is the because the condenser is getting too hot. it needs to be fix or the compressor life will be greatly shortend
Nov 20, 2007 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
48 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
