Question about HP OfficeJet 7310 All-In-One InkJet Printer
Vertical lines (no printing) on copy
How do access the command to clean print head?
  • donbhoff Nov 13, 2008
    The "guru" after a couple of false starts told me to oput a sheet of paper in the feeder; press "Setup" put in 6 & 1.
    Voila! It worked.
    Thanks for your input.
    Problem Solver:
  • 12 Answers
Make sure you have visited the HP web site for the OfficeJet 7310 (it's not the 10xi model, is it?)
Check out the page on troubleshooting copying problems.
See if your vertical lines issue is addressed on this page.
Posted on Nov 08, 2008
Ir 400 machine ccd in the copy horizontal lines problem what is the solution
Cleaning the ink jets of the print head, adjusting the vertical alignment and/or replacing the ink cartridges may improve print quality. You will first need to identify which cartridge(s) need to be cleaned by printing a Print Quality Check Sheet.
Nov 12, 2017 | Cameras
When I print the pages are clean, but when I make a copy there are vertical lines on the page
hi there is problem with print head yours print head is blocked, there is way to open blocked head if you are technical you should have to remove ink and then you can takeout print head.
there is the way to open blocked head without any coast.
1. remove print head from printer.
2. take your print head in to wash sink.
3. keep upper side down of print head under the water tab & open water for 10 minut.
4. dry water from print head.
5. reset back print head in to printer make copy or just run clean print head from tools.
remember me in yours prayers
Sep 22, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
Printing is not clear some long white lines
This sounds like you are running low on ink, your print heads are clogged or are out of alignment. I would buy a new All-in-One because of the low cost of new ones these days but if you want to make this one work try using the printer software and find clean print heads and/or align print heads. If that doesn't work try new ink. Good Luck!
Jun 06, 2014 | Panasonic KX-MB2010 All-In-One Laser...
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
My hp officejet 6210 all in one is instaled under general heading: officejet 6200 series. Result: the printer reacts to command given by laptop windows xp but does not print given text. The paper comes out...
Are you able to print Self test page from printer ( standalone ) or able to make a copy ? if you are able to make copy/print self test page from printer, this issue is with Printer Drivers, You can uninstall and reinstall the software ( download the latest software and drivers from HP website )
If you are not able to make copy/print self test page from printer, it is issue with printer/cartridges... you need to re-align the printer
to clean/align cartridge
On Printer Front panel
Press - Setup Button ( press ok)
Press - Tools ( Press Ok )
Press - Clean Cartridges ( Press OK )
Press - Align Cartridges ( Press OK )
Jun 22, 2010 | Office Equipment & Supplies
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Vertical print residue left about half inch past the longest line printed
inside the front cover, under where the head parks, you will find a vertical wiper. Clean it.
Power off. open front door. push down cutter (blue) and slide head to the left. To the right of the cleaning pad is the wiper. clean with rubbing alcohol on both sides.
Run a normal cleaning.
All set
NOTE: you do not need to put the head back in place. when you power on it will automaticly park itself
Nov 06, 2008 | Epson Stylus Pro 9800 InkJet Printer
MP780 vertical lines on photos
Hi. the problem is the print head, maybe is clogged or damage, try this remove the cartridges , and the print head and submerge the print head in hot water for 3 minutes, dry the print head and reinstall it, if problem persist replace the print head.
TCT How to remove and clean Canon Printhead
May 02, 2017 | Canon PIXMA MP780 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
135 people viewed this question
Ben Johnson
