Question about Lenovo 3000 V100 Notebook
My laptop seems like its stuck in sleep mode..
The only light that comes on when i power up my battery light and the circle with the Z through it. Does anybody no how to get it back on and running????
Shareece in Canada.
  • lijith007 Nov 10, 2008
    I had a problem in the OS so i restarted the sysytem but after that the only light that comes on when i power up my battery light and the circle with the Z through it. Does anybody no how to get it back on and running????
MSI L1600 netbook seems to be stuck in sleep mode. The power also cannot be turned off - even removing the battery and replacing it.
try to boot the computer, if you hear the start up sound then mobo is not bad. this issue could be caused due to boot sector viruses as well. see if the back light turns on ..
check the settings in bios and try to run a recovery. if neither helps
call 1-877-805-1027 for expert help
Jul 30, 2015 | MSI Computers & Internet
Stuck on sleep mode
Unplug the AC adapter, detach the main battery, press the power button for 15 seconds. Attach the main battery, and restart the laptop.
Feb 12, 2014 | HP Pavilion Dv7-4065Dx Laptop Lcd Screen...
Stuck in sleep mode
remove the battery and unplug your power chord for 1 min. then plug your power chord back in and try to turn it back on.
if it works then plug your battery back in and see if it boots your system up without the power chord.
if everything works fine then go into your control panel and change your power options.
Asus k50 will not start
If the light on the pc, not the power supply is orange this usually means the pc is not comming out of sleep mode. Try the obvious and restart it. If that does not work, attempt starting in safe mode and go to your control panel and turn off all power saving, screen saver, and sleep mode options.
Sep 24, 2012 | ASUS K50 Series K50IJ-G1B NoteBook Intel...
Acer3000 yellow light solid and will not power on Help! Is this motherboard issues?
It's very possible you have motherboard issues. Hardware failures will often resemble the machine being stuck in "sleep mode". You can try a power "reset" in case it is stuck in sleep mode. Press and hold the power button for 30 seconds. If successful, the machine will boot (probably in safe mode) and you should be able to re-configure your power settings to disable sleep mode. If this doesn't work, you most likely have hardware issues and the motherboard is most likely the culprit.
Aug 20, 2011 | Acer Computers & Internet
I was using laptop, closed the top to put to sleep, on opening up back the laptop i disconnected power supoly for is was plugged in and then my computer shut off, it seems the battery is not responding...
sleep mode if all the hardware is still on, not what to perpergian sebantar pake sleep mode, for a long time you turn off / Shutdown. You can also laptops batterynya already can not store electricity. you try to charge back or replace a new Battery
Jul 27, 2011 | Acer Computers & Internet
I have an EVESHAM MS-17188B Laptop. Stuck in sleep mode! The Problem is when ever I turn it on, the power and sleep mode light is active. But nothing else, the screen stays blank, and cant hear any fans...
First advice would have been to remove battery, but since you did that, I'd say that your laptop is stuck in hybrid-sleep, or the old hibernate. Try pressing the power button for 10-15 seconds, the laptop should go off, then try presing the power button again, for normal boot.
May 05, 2011 | Computers & Internet
I can't get my IBM ThinkPd out of sleep mode. (I'm using another computer right now.) I tried taking the battery out and unplugging it for 20 minutes, pressing power button, holding power button down,...
It sounds like a failed motherboard, If it was stuck in sleep mode the computer would still turn on.
try leaving the battery removed plug in the laptop and see if it turns on, if not it sounds like a bad component on the motherboard.
Apr 06, 2011 | IBM ThinkPad T23 2647 Notebook
My laptop has went into hibernation and shows a small moon and that the battery is in use. I took out the battery and it still shows it in use. It won't come out of hibernation and won't go back to...
The moon means Sleep or standby mode, if the laptop attempted to enter hibernation and sleep mode at the same time it could just be stuck in a hibernation loop and unable to load.
To test this, remove the battery and AC adapter, then hold your power button down for thirty seconds. Once you've done this replace the battery and power cord then try turning it on.
Let me know how you make out and if it doesn't work provide any other details you can including anything that comes on the screen and any beep codes you hear as it fires up.
Thanks and good luck,
Chris
Aug 10, 2009 | IBM ThinkPad T20 2647 Notebook
Powering up a dell d610 laptop
remove the battery and start the machine on AC power only, see if this helps
keep us informed
regards
Nov 24, 2008 | Dell Latitude D610 Notebook
Lenovo 3000 V100 Notebook Logo
496 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
