Question about Jenn-Air 24 in. DW731 Built-in Dishwasher
Leak off pump housing
Unit leaks off bottom of pump housing with drip, damaging floor. But, I can't see where it's coming from. Doesnt' appear to be main ring at top or from drain tube connection. Drip is not at steady pace.
  • Dan Krueger Oct 28, 2006
    leak was thru the impeller seal. Thanks much for advice.
  • ladyplumber Apr 18, 2008
    How do you get the pump out to remove the impeller?
    President:
  • 878 Answers
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. Catriver..post back.
Posted on Oct 23, 2006
Hot Water is coming out of our hydronic heating unit outside through what appears to be an overflow pipe. Also water is dripping out of a connection onto bathroom floor . Any diagnoses?
hot water coming our sounds like the oressure relief valve operation. Check the water pressure gage is not 3 bar or above. Water dripping is a leak from one of the pipes or more likely joints or other water connections. to the unit. trace water upwards to highest point and there is the leak
Jul 28, 2018 | Heating & Cooling
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Whirlpool duet leaking water from bottom of washer-after I noticed the water on the floor from the washer leaking from underneath, I took the clothes out and tried to run the machine without clothes in it....
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 01, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Leaking water
mcdevito75 here, The portion of the a/c unit that goes outside the window is the evaporator and suppose to leak water, check the drain hole in the unit floor on the outside portion of the unit, reach this drain hole thru another window or have your local a/c repair shop look at it, they come to the house.
Jun 21, 2010 | Samsung AW0893L Air Conditioner
Our Fisher & Paykel single dish drawer unit (6 months old) is leaking limited water from its base down the front of bottom drawer below the unit's base onto the kitchen floor. One inspection by a...
One drawer leaks can cause this problem. If you don't fix it. One day it will turn on the pumps from both units without any one touching them since the floor sensor at the bottom housing detects water and it will run for ever until you unplug the power cord. This dishwasher is a state of art in design and replacing parts is very simple once a person has enough understanding of its mechanism. If the tech fail to find the problem then he is not qualified to touch this dishwasher. When there is a leak, it is a problem with the lid seal from the top not closing down tightly so during the wash cycle, water shoot up and leaks through the top opening then collecting on the bottom housing of each unit. Let say the top draw is leak, so the bottom housing of top draw if full of water then it overflows to the bottom drawer unit then the floor. Here is the idea of how it happens. The top lid is pulled down by 2 actuators from both sides at first start. That is why you can hear the motor noise turning on at the beginning of the wash cycle. That is the noise from the actuators. If the actuators are bad. only one side works then the lid can not be sealed properly there is a leak. If bothe of actuators are week the gear worn out so they can not hold the lid down during the wash cycle then it can cause a leak. You can pull each tube out and access from the left side at the bottom to touch the bottom housing to fell the wetness. Put in tower to dry them out. If there is a weteness from the bottom housing upper tube it doesn't mean the bottom drawers is leaking. It is wet just because the top is leaking. However you have to dry the bottom in order to continue use the bottom dryer. If you ignore my advice then your circuit board at the bottom housing of lower drawer will be damaged and it is not cheap. With the information that I provided you can interview a tech claiming know about the this type of dishwasher before letting him coming into your house. Good luck.
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool duet washer model # GHW9100W pours water on the floor
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Danby DDW496W Leaking Brand new
Check your hose connections in the back for tightness and sealing (there should be some rubber seals inside the screw-in connections) and if tight and not leaking, you might have a loose clamp inside the unit, or a leaking/damaged hose, or even a defective/leaking pump. If it is brand new and returnable I'd return it for a new one rather than try to fix it...
Apr 05, 2008 | Danby DDW496W Free-Standing Dishwasher
Dishwashers Logo
699 people viewed this question
Top Jenn-Air Dishwashers Experts
Marvin
Marvin
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
