System isn't sensing the pressure to do a normal startup on car. Most times car will start if I do half start 4x fast and then on 4th turn engine all the way over. Am tired of dealing with this problem. Have replaced - tranny filter (fluid), fuel pump, and a new battery put in. I'm not quite sure what I'm talking about, but. Can you give help?
Is the engine actually cranking when it doesnt start or do you hear just one "click" each time you turn the key? if the engine is cranking, i would suspect a fuel problem, possibly fuel filter if it wasnt changed when the fuel pump was done. if it is not cranking and you hear one "click" upon turning the key, i would suspect faulty starter or connection problem.
